Ex has a remote start?
Old Jan 28, 2018 | 12:01 PM
Per4mance's Avatar
Per4mance
I discovered by accident that my Ex has a remote start. It cranks it but it doesn't fire up. Anybody have experience with remote starts. It's not factory. I think the brand is Volant.
Old Jan 28, 2018 | 12:46 PM
tomsoftail's Avatar
tomsoftail
Does it have a glow plugs delay???
Next time you drive for a while try the remote start while it's hot.
Old Jan 28, 2018 | 12:57 PM
Per4mance's Avatar
Per4mance
Ya ,I did that's how I found it. It the key fob one too many times.
Old Jan 28, 2018 | 12:58 PM
navistarnut's Avatar
navistarnut
Funny you mention that brand, which I think is actualy Avital branded. Our Odyssey has that brand as well, and it's garbage.
Won't hold a re program, works sometimes just fine, then it won't.
I'm wondering your PO had issues and just ditched it?
That was the case with us.....bought the van last summer, knew it had the remote start but the owner at the time who was the second owner, said it had not worked since he had it at 40k miles 8 years prior to us buying it.
There are instructions/info online.
Avital - Home - Car Alarms | Remote Starters | SmartStart
Old Jan 28, 2018 | 03:30 PM
Per4mance's Avatar
Per4mance
Thanks I'll check it out. Right now I'm trying to fine the Blue Tooth driver on my computer. I think it might have gotten booted or something. I hate this windows 10.
Old Jan 28, 2018 | 05:56 PM
tfunk88's Avatar
tfunk88
It might not be starting because of a PATS issue. Try the remote start with your key actually in the ignition (not turned to any position, just put it in). This will put the PATS chip in the key close enough so that the PATS system won’t activate. I know several people have simply attached a coded chip next to the ignition cylinder so they can use a remote start. But if you do that then any non-chipped key will start your truck if it will allow the lock to turn. Or if someone busts it with a screwdriver.
Old Jan 28, 2018 | 06:57 PM
Don Naslund's Avatar
Don Naslund
Mine wont remote start with the hood up. It will also kill the engine if I don't turn the key on before turning the ignition key to the run before touching the brake pedal. A problem with one of those safety sensors could be your problem.
snotrod
2015 + Expedition & Navigator
Apr 4, 2018 04:00 PM
jez
Nov 18, 2012 08:47 PM
XBuford
36
Jan 21, 2010 05:47 PM
snoskier
May 24, 2004 08:23 PM
