2008 Ford F250SD 6.4L 150K miles shows 2 codes and check engine light.
P0001 Fuel Volume Regulator Control Circuit
P0004 Fuel Volume Regulator Control Circuit High
Will changing the Fuel Volume Regulator fix the issue?
It appears to be an easy replacement and cost less than 200 dollars.
Should I give it a go?
