2008 F250 Charge Air Cooler - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > Diesel > 6.4L Power Stroke Diesel
Reload this Page >
6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Old 01-28-2018, 02:03 PM
Miker13
Miker13 is offline
Miker13 is starting off with a positive reputation.
Is the Charge Air Cooler easy to access in
A 2008 F250 6.4L diesel?
Old 01-28-2018, 02:44 PM
Firefighter 1406's Avatar
Firefighter 1406
Firefighter 1406 is offline
Firefighter 1406 has a great reputation on FTE.Firefighter 1406 has a great reputation on FTE.Firefighter 1406 has a great reputation on FTE.Firefighter 1406 has a great reputation on FTE.
I am assuming you mean intercooler. In that cause yep super easy. Remove the fuel cooler on the drivers side of the radiator, 2-10mm bolts. Then the intercooler is 4-7/16 clamps and two 13 mm bolts and it’s out. Super easy.
Old 01-28-2018, 06:32 PM
DieselDenny
DieselDenny is online now
DieselDenny has a great reputation on FTE.DieselDenny has a great reputation on FTE.DieselDenny has a great reputation on FTE.DieselDenny has a great reputation on FTE.
Curious about the question.............
What is the problem with the CAC?
Denny
Old 01-28-2018, 08:27 PM
Miker13
Miker13 is offline
White smoke
the issue is white smoke when accelerating from stop moderate to high speed. The more acceleration the more smoke.
Old 01-30-2018, 12:25 PM
Martin6
Martin6 is offline
Martin6 is starting off with a positive reputation.
Are going to replace it with OEM or aftermaket?
Old 01-30-2018, 01:36 PM
Copper.Farm's Avatar
Copper.Farm
Copper.Farm is offline
Copper.Farm is gaining momentum as a positive member of FTE.Copper.Farm is gaining momentum as a positive member of FTE.
White smoke could be caused by regeneration or water in the combustion chamber.
Is the truck deleted?
Has the truck been tuned with tunes that advance the timing?
Any overheating problems?
What temperature is the coolant as you are driving down the interstate?
Supercab
11-15-2010 03:23 PM
DGMFORD
1999 to 2016 Super Duty
01-07-2010 04:11 PM
camsford
1997 - 2003 F150
12-05-2009 08:04 PM
camsford
12-05-2009 12:30 PM
spacecoast
Electrical Systems/Wiring
10-23-2002 09:52 PM
Quick Reply: 2008 F250 Charge Air Cooler
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
