Vsm not where it should be? 2002 super duty
The VSM is present ONLY it the truck was factory-equipped with remote keyless entry. If equipped, it will be behind the HVAC and radio control panel. Remove the lower center trim to access.
If not equipped, the door ajar switches (which usually get gummed up from hardened grease) are wired directly into the instrument cluster. The power lock actuators are directly controlled by the door switches.
FordPowerStroke
03-26-2011 06:11 PM
