Always something, but I love her anyways.
#47
#48
on
The way the doors are, there is an outer skin and inner skin. There is a big hole in the outer skin, and the studs go through that to rest flush on the inner skin. The studs in the new mirrors are ever so slightly larger than the hole in the outer skin on the bottom 2 holes, so the mirror won't sit flush. You can drill the holes bigger, but in order to do it without fooling with the truck you can file the base of the studs to fit through the holes
You have full power with the mirrors and have you tried the heat function yet?
I got mirrors from Twitchy's group buy a while back and they are great, but have a few buddies wanting them, too. With vibration and quality issues out there, I didn't know what to recommend. Now I do
Thanks! Reps
#49
#51
What rpm range do you all see boost when unloaded? Going uphill, at WOT, I don't see any boost until about 2k RPMs. I know there's no boost leak now, as all my boots are brand new, and there is no soot on the firewall from the up pipes. I am getting 18 pounds now with the new boots, but I get nothing below 2k RPMs. Is that normal?
#52
Are you seeing anything on the gauge when cruising at say 65 MPH? My boost will hover around 4-6 when cruising. If I get on it and run through the gears it will spike to ~32 PSI. When towing I can comfortably climb to ~28 PSI at 2800 RPM and hold it there as I ascend a grade.
As for unloaded, I will see it go up to near 20 at 2800 or so when just normal accelerating. I cannot remember where the boost is at near 2000 RPM, but if you are getting nothing, then there may be an issue. You should be getting something, I would guess around 5 at low RPM.
#53
#54
I haven't properly hooked up the heat on my mirrors yet - they've been there maybe three years now - as my truck had fully manual mirrors OEM. I have a length of wire hanging out and I plug it into the cigarette lighter when I need it. One thing I've seen, if I keep the windows folded, they don't seem to ice up as much during the night when it snows.
#56
#60
