Always something, but I love her anyways. - Page 4 - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > Diesel > 1999 - 2003 7.3L Power Stroke Diesel
Reload this Page >
  #46
Old 02-04-2018, 07:53 AM
afmedic
afmedic is offline
afmedic has a good reputation on FTE.afmedic has a good reputation on FTE.afmedic has a good reputation on FTE.
Sand the red part
  #47
Old 02-04-2018, 08:09 AM
Sous's Avatar
Sous
Sous is online now
Sous has a spectacular reputation.Sous has a spectacular reputation.Sous has a spectacular reputation.Sous has a spectacular reputation.Sous has a spectacular reputation.Sous has a spectacular reputation.Sous has a spectacular reputation.Sous has a spectacular reputation.Sous has a spectacular reputation.Sous has a spectacular reputation.Sous has a spectacular reputation.
Got it! Makes sense now. Thanks again. I am sure this will serve as a great reference point for mirrors in the future.
Reps sent your way sir!
  #48
Old 02-04-2018, 08:47 AM
ExPACamper
ExPACamper is offline
ExPACamper has a brilliant futureExPACamper has a brilliant futureExPACamper has a brilliant futureExPACamper has a brilliant futureExPACamper has a brilliant futureExPACamper has a brilliant futureExPACamper has a brilliant futureExPACamper has a brilliant futureExPACamper has a brilliant futureExPACamper has a brilliant futureExPACamper has a brilliant future
Originally Posted by afmedic View Post
The way the doors are, there is an outer skin and inner skin. There is a big hole in the outer skin, and the studs go through that to rest flush on the inner skin. The studs in the new mirrors are ever so slightly larger than the hole in the outer skin on the bottom 2 holes, so the mirror won't sit flush. You can drill the holes bigger, but in order to do it without fooling with the truck you can file the base of the studs to fit through the holes
Nice catch! So what you're saying is DON'T just beat it with a hammer? LOL
You have full power with the mirrors and have you tried the heat function yet?
I got mirrors from Twitchy's group buy a while back and they are great, but have a few buddies wanting them, too. With vibration and quality issues out there, I didn't know what to recommend. Now I do
Thanks! Reps
  #49
Old 02-04-2018, 09:11 AM
Sous's Avatar
Sous
Sous is online now
On a personal level, I don't plan to use the heat or the turn signals. I just wanted the larger mirror surface with the power adjusting option. With the reviews that the seller has, I don't anticipate any problems.
  #50
Old 02-04-2018, 09:19 AM
afmedic
afmedic is offline
I am not going to hook up the heat, but I'm going to hook up the signal as the marker light.
  #51
Old 02-04-2018, 09:24 AM
afmedic
afmedic is offline
What rpm range do you all see boost when unloaded? Going uphill, at WOT, I don't see any boost until about 2k RPMs. I know there's no boost leak now, as all my boots are brand new, and there is no soot on the firewall from the up pipes. I am getting 18 pounds now with the new boots, but I get nothing below 2k RPMs. Is that normal?
  #52
Old 02-04-2018, 09:33 AM
Sous's Avatar
Sous
Sous is online now
Are you seeing anything on the gauge when cruising at say 65 MPH? My boost will hover around 4-6 when cruising. If I get on it and run through the gears it will spike to ~32 PSI. When towing I can comfortably climb to ~28 PSI at 2800 RPM and hold it there as I ascend a grade.
As for unloaded, I will see it go up to near 20 at 2800 or so when just normal accelerating. I cannot remember where the boost is at near 2000 RPM, but if you are getting nothing, then there may be an issue. You should be getting something, I would guess around 5 at low RPM.
  #53
Old 02-04-2018, 09:44 AM
afmedic
afmedic is offline
I get 4 pounds cruising at 65-70. I guess that's normal then! I'm going to inspect my compressor wheel real good when I put the new tubes on this week and see if there is any damage on the fins
  #54
Old 02-04-2018, 09:51 AM
SaintITC
SaintITC is offline
SaintITC has a great reputation on FTE.SaintITC has a great reputation on FTE.SaintITC has a great reputation on FTE.SaintITC has a great reputation on FTE.SaintITC has a great reputation on FTE.SaintITC has a great reputation on FTE.
I haven't properly hooked up the heat on my mirrors yet - they've been there maybe three years now - as my truck had fully manual mirrors OEM. I have a length of wire hanging out and I plug it into the cigarette lighter when I need it. One thing I've seen, if I keep the windows folded, they don't seem to ice up as much during the night when it snows.
  #55
Old 02-04-2018, 10:11 AM
ExPACamper
Heat works to defog them, too
  #56
Old 02-04-2018, 04:37 PM
afmedic
afmedic is offline
I saw 22 pounds of boost on my way home at 90mph and WOT. Cruising at 70 I get 8, so I think I'm a little more where I should be this is with the Watergate disconnected though. It sure beats the 12 lbs I was maxing at before replacing the boots
  #57
Old 02-04-2018, 05:05 PM
ExPACamper
Nice! Do you have a tuner or boost fooler?
  #58
Old 02-04-2018, 05:09 PM
afmedic
afmedic is offline
I don't have a tuner or a boost fooler. I'd like a tuner, but I'm saving my pennies for the hydra
  #59
Old 02-04-2018, 08:38 PM
ExPACamper
Smart idea, IMHO.
IIRC, about 22psi is all you'll get stock, as the PCM will defuel about that boost level.
  #60
Old 02-04-2018, 10:55 PM
Sous's Avatar
Sous
Sous is online now
You are right where you should be with no tuner, good work.
Quick Reply: Always something, but I love her anyways.
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
