Fuel tank
Old Jan 21, 2018 | 06:15 AM
green_95's Avatar
green_95
Fuel tank
Filled my 97 f250 up yesterday, drove to get something to eat, came out from eating to a puddle of diesel fuel and the tank with a pretty steady drip. Is there any difference I the diesel vs gas tanks for our obs trucks? Is it a diesel specific tank?
Old Jan 21, 2018 | 10:54 AM
Red97350's Avatar
Red97350
The tanks are the same between the gas and diesel. The only issue you might run in to is if your front tank is plastic. I don't think anyone reproduces that tank.
Red
Old Jan 21, 2018 | 11:41 AM
green_95's Avatar
green_95
Red
it's a metal tank. While it's out I am going to go ahead and replace my driver side cab mount bushings. I dI'd the passenger side last spring, but didn't feel like dropping the tank to get to the driver side.
Old Jan 21, 2018 | 11:45 AM
97-psd's Avatar
97-psd
Make sure where the leak is coming from. The clamp for the full hose may just need to be tightened
Old Jan 21, 2018 | 01:19 PM
humphrey169's Avatar
humphrey169
Gas and Diesel tanks are technically different. Its the filler neck that is different. Gas has a small ring for the breather tube. I have a gas version in my diesel truck, i just ripped that piece out so the diesel fill hose will fit.
Old Jan 21, 2018 | 02:04 PM
green_95's Avatar
green_95
it's defiantly got a hole in the bottom, it's a steady stream running. I'm almost suspect that someone may have purposely put a hole in it. I'll know more when I get the skid plate off it.
Old Jan 21, 2018 | 03:49 PM
97-psd's Avatar
97-psd
Oh crap that is not good. As a temp fix you can buy epoxy putty for fuel tanks. The good stuff will even stop an active leak. Good luck
Old Jan 21, 2018 | 05:19 PM
97-psd's Avatar
97-psd
deleted. Double post
Old Jan 23, 2018 | 07:56 AM
Jarrett Campbell's Avatar
Jarrett Campbell
I found a brand new tank on Amazon for like 65$
When mine had a leak, it was from small rocks getting caught between the skid plate and the tank... Crappy design.
Old Jan 23, 2018 | 10:02 AM
mcali2's Avatar
mcali2
Red
I have an extra plastic front tank if you need one.
Old Jan 23, 2018 | 10:04 AM
mcali2's Avatar
mcali2
When I did my tanks , I built in 1.5" of space between the skid and tanks.
Dave Dickson
General Diesel Discussion
Oct 1, 2019 05:58 AM
ericconn
May 4, 2013 08:29 PM
JOHNNYRICH10
Nov 12, 2010 02:21 PM
linckeil
Aug 23, 2010 09:43 AM
DEREK D.
May 24, 2006 04:09 PM
