BAD DIESEL??
Old Nov 12, 2010 | 09:55 AM
JOHNNYRICH10's Avatar
JOHNNYRICH10
BAD DIESEL??
Ok, I know we are really not supposed to get below 1/4 of a tank but last monthI did. And right at less then 1/4 of a tank it starts bogging down, and died like i am ran out of diesel. I went and got 5 gallons and put in it and it started and got it to the gas station and filled her up. Ran fine. I figued if it was bad diesel it would all mix and be fine after that. So this time i decided to go to less then 1/4 tank again to see if the problem was resolved. had the exact same problem.
Old Nov 12, 2010 | 10:04 AM
cj45lc's Avatar
cj45lc
Do a search for in tank mods. Sounds like your sucking air in the duckbill on the mixing chamber in the fuel tank
Old Nov 12, 2010 | 12:42 PM
bulla's Avatar
bulla
If there was trash in the tank you would be having that problem even after you fill up. The pick up umbrella is right on the bottom of the tank where the trash would be. Run it to a 1/4 tank and see if it does it again. If so it's probly catching air and the in tank mods need to be done. Unless you never plan on running the tank low again. I plan To burn every bit I put incase something goes wrong and I need that extra 100 miles.
Old Nov 12, 2010 | 02:21 PM
husker's Avatar
husker
Another possibility is that the guage is off. How many gallons of fuel does your tank take when it is close to 1/4 tank? Short bed/longbed will make a difference in tank capacity.
7.3L_Newbee
May 10, 2014 07:21 AM
cajunsuperduty
Jun 29, 2013 10:12 PM
mytoys2037
Oct 31, 2010 12:01 AM
Sawbones25
Modular V8 (4.6L, 5.4L)
May 11, 2007 11:39 AM
Bad Company
Oct 29, 2004 10:14 AM
