2015 + Expedition & Navigator 2015 + Ford Expedition and Lincoln Navigator
2016 - 2018 Oil Change simplified
Old 01-20-2018, 08:40 AM
FreeWill's Avatar
FreeWill
FreeWill is offline
Actually this will work for 2015+ 3.5 V6.
I watched YouTube videos on how to do this and thought it was crazy to try and contort my arm in the blind from under the vehicle to get the oil filter off.
Opened the hood and realized you can stand on a stool (I'm only 5'8"), reach down behind the radiator, and throw a strap wrench on the filter and pull it off. It's right on the front left side of the engine.
Easy, or at least not virtually impossible like the underneath method.
Old 01-21-2018, 06:18 AM
glockholiday's Avatar
glockholiday
glockholiday is offline
That's how I do it but now if there was only a way to keep the oil from running all over the place when you remove the filter. I've even tried having the rear tires up on ramps and it still won't run out the spout of that drip tray like it's supposed to.
This is the only vehicle I take in for an oil change.
Old 01-21-2018, 08:22 AM
jschira's Avatar
jschira
jschira is offline
I wad up a bunch of paper towels and put them in the drip tray.
Then I wipe down the tray with more paper towels sprayed with brake cleaner.
Old 01-21-2018, 04:47 PM
FreeWill's Avatar
FreeWill
FreeWill is offline
I basically did what jschira does. Next time thinking about putting a little 1" high platter down there to try and catch the oil. If you move fast you'll get just a little oil on the towels.
Old 01-22-2018, 08:43 AM
1NiceHarley's Avatar
1NiceHarley
1NiceHarley is offline
I don't have the 3.5 but it sounds like the same stupid oil filter location/tray as my 2015 F150. I built a oil catch that attaches to the back of my drip tray on the 150. I cut a quart oil bottle up so that it has a hook on it and it hangs off the aft side of the drip tray it catches the oil that comes off the aft side and I have my normal oil pan under the front side. After the oil drains out, I wipe down the tray and no oil mess on the floor.
If this sounds like what you have on the 3.5 let me know and I'll take some pictures.
We are looking at getting a 16-17 Navigator so I am trying to get schooled on the 3.5.
Old 01-22-2018, 08:50 PM
glockholiday
Yes Expedition and F150 3.5 EB is the same set up.
Redrockerstl55
2017+ Super Duty
26
03-29-2020 12:56 PM
Ressinoff
11-14-2016 04:34 PM
Sarge2155
2004 - 2008 F150
04-24-2007 06:12 AM
eager_49
Oil & Lubrication
06-10-2003 10:51 PM
solexx
01-22-2002 09:10 PM
Quick Reply: 2016 - 2018 Oil Change simplified
