2002 Ford Explorer 4x4 Transfer Case Problems
Old Jan 19, 2018 | 04:45 PM
KC Excursion's Avatar
KC Excursion
Hi,
I've read many many threads and I believe my problem to be the transfer case....none of the threads I read have my symptoms though. This all occurred in the last 10 miles
2002 ford explorer, 4x4, eddie bauer.
Here is goes......
The truck jerks/bucks while at a complete stop with the
brake brake
depressed. It's a thump, thump, thump that comes from the transfer case
The thump gets better while driving and no brake being used
The thump is present in 4A, 4H or 4L
Unplugged the transfer case electrical and removed all 3 fuses.....same thumping, forward or reverse, 4h or 4l
All four wheels off the ground....thump, thump thump while brake depressed, let off the
brake brake
and the noise goes away.
I don't understand this - all wheels off the ground, brake depressed, the drive shaft is turning. I'm not familiar with this
rear differential rear differential
but I noticed is also has an electrical connection. It's a limited slip differential However, with vehicle off the wheels will turn independently - at other times it will engage the opposite
wheel wheel
in counter-rotation which is what i expect.
Finally - transmission in park - the
truck truck
will roll sometimes but not all - leading me back to the transfer case.
Please help....
-Kevin
Old Feb 11, 2018 | 06:44 PM
MirekJ's Avatar
MirekJ
The transfer case is the main problem.I have a 1998 Exp with 5L engine 4WDA and one day we have found my truck down the street (40 yards) away .
I contacted JASPER supplier and got a OVH case, changed my self, it works .That happened at 160 K, now I have a 330K and changed oil once since , still working good.
VR Mirek
Old Feb 11, 2018 | 10:04 PM
steve(ill)'s Avatar
steve(ill)
I don't understand this - all wheels off the ground, brake depressed, the drive shaft is turning. I'm not familiar with this differential,
how can the drive shaft turn if the brakes are locked and tires not rotating ? The electrical plug on the top of the pumpkin is for the ABS ---
dino360
2004 - 2008 F150
Oct 26, 2018 01:50 PM
Superdutyangel219
May 28, 2016 12:19 PM
MichiganMikey
2004 - 2008 F150
Jun 25, 2013 03:30 PM
caverjoe
Apr 18, 2012 09:26 PM
highoctane74
Sep 30, 2009 02:57 PM
