E40d help
Old Jan 18, 2018 | 09:35 PM
Bwinckler's Avatar
Bwinckler
E40d help
Okay so I have a 1995 F150 with an e4od and I am planning to buy a 1992 e4od will I have any troubles with the electrical plugs because the person I am buying it from says that they changed the plugs Style in 1994. is that true?
Old Jan 18, 2018 | 09:42 PM
mrollings53's Avatar
mrollings53
Some functions moved around between the PCM, and the transmission around '94-'95. I can't remember the specifics. I do know that it is best to keep things paired together. Each model year transmission, PCM, and wiring harness stay together. Mark will probably see this thread and hopefully chime in.
Old Jan 19, 2018 | 07:28 AM
Redark1's Avatar
Redark1
afaik you don't want to go back past 94.
Old Jan 19, 2018 | 09:09 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
If you put a 1995 solenoid body and transmission range sensor in the trans it will work.
Old Jan 19, 2018 | 09:42 PM
Da_Lariat_Chariot's Avatar
Da_Lariat_Chariot
The 95 and up E4OD had many improvements over the previous years. If it was me I would keep the 95 and rebuild it, or you should take the 92 and modify it using 95 parts. It boils down to improved internals, makes it last longer and function better overall.
Old Jan 20, 2018 | 10:30 AM
Bwinckler's Avatar
Bwinckler
How much do you guys think a rebuild is if I brought the trans in myself and trans place didn't have to remove it.
or
I found a 92 with 10,000 miles for $275
(and put a new solenoid pack in)
idk which would be better in the long run
Old Jan 20, 2018 | 10:58 AM
HardScrabble's Avatar
HardScrabble
Temporarily Deactivated
What is wrong with the old transmission?
Anything that old is all about condition. A used one is a crap shoot no matter what revision level. A rebuild is expensive no matter what. Last I checked, cheap rebuilds were about $900 with pathetic support.
If you get the used one, renew all of the wiring connections and get a fluid lab analysis at 1500 or so miles; it would be cheapest and maybe better than a cheap rebuild.
IF you really need a rebuild?
Old Jan 20, 2018 | 11:55 AM
mrollings53
I bought a rebuilt transmission from a local company for about $2500; labor to install was about $750.
Old Jan 20, 2018 | 12:25 PM
GoinBoarding's Avatar
GoinBoarding
×2
Don't mean to offend your (the OP) intelligence, but more than once people have swapped transmissions only to have the same issues so I must ask. How have you determined that the 95' E4OD needs a rebuild?
Old Jan 22, 2018 | 11:29 PM
Bwinckler's Avatar
Bwinckler
The trans has been slipping like crazy lately and has been leaking from the pan and the torque inverter seal. It wouldn't be uncommon tho put in a quart of atf in about every week or so, I would check the fluid level every day and it finally gave up the gohst yesterday. I was hanging out with some friends and I noticed it loosing power, then not moving at stoplights and finally I parked it and left it for the next day, a friend and I flat towed it to my house and I haven't touched it since because I've been incredibly busy.
Old Jan 22, 2018 | 11:55 PM
jason90f150's Avatar
jason90f150
I would get a monster e4od. I think you can get them for around 1800. I should have went that route when mine failed, but I decided to go with a 4 speed T18. Go big or go home is what I learned from my experience
Old Jan 23, 2018 | 12:27 AM
mrollings53
I would get something where a warranty repair isn't a two week wait while the transmission is in the mail. Plus I don't have to worry about doing the R&R myself.
BWD444
Dec 22, 2016 10:05 AM
Sk8rbrdly11
Jul 18, 2016 09:35 AM
BORDERBUM
May 22, 2014 03:12 AM
hav24wheel
Oct 28, 2010 07:46 AM
pchristman
Feb 3, 2006 01:09 PM
