fuel pump issue
Old Jan 17, 2018 | 10:32 AM
Ih1466's Avatar
Ih1466
fuel pump issue
Thought I would post my problem I ran into. 05 6.0 coming home from work the other day going up a hill it started to loose power. I thought the fuel might me gelling up because it was 10 deg outside. put new fuel filters in it same issue so i put a fuel gauge on it and on flat ground it would hold 65 psi. so i backed down my driveway that has a little down grade and it went to 0 psi. i had just above a 1/4 tank of fuel thought maybe the sending unit broke off in the tank so I put 10 gallons of fuel in the tank same thing again park on a hill and fuel pressure dropped. put a new fuel pump in it and has been fine since thought it was strange so I figured I would share.
Old Jan 17, 2018 | 10:53 AM
got2befast's Avatar
got2befast
Did you ever lose power while driving down a hill or on flat surface? My truck is currently sitting on the side of the road due to very similar issue.
Old Jan 17, 2018 | 11:04 AM
Ih1466's Avatar
Ih1466
mine just seemed to be going up hill. but it happen about a mile away from my house. so it could have been both. my pump sounded fine but when I put a fuel gauge on it it dropped like i shut the key off.
Old Jan 17, 2018 | 11:05 AM
got2befast's Avatar
got2befast
Ok once i get it to my work I will look into it and see what is going on.
cabloom300
Apr 14, 2019 08:23 AM
DrFord
Oct 20, 2013 09:46 AM
edub32
56
Jul 21, 2009 06:30 PM
86F150302
Dec 13, 2008 12:03 AM
daneddy
Apr 23, 2003 07:51 PM
