Was driving down the road, truck wouldn't accelerate it felt like it was dying. Came to a stop light and the truck staled, it took a few times to start back up but would keep staling on hard stops. I replaced my ICP, my filters, and now my FICM and still the truck wont start. it will turn over but will not start.
The code number might help in troubleshooting. So might actual engine data (ICP pressure, ICP volts, IPR % duty cycle). It might have been the sensor or wiring with an electrical code. Another ICP code is for low pressure. In an 05 this usually is either dummy plugs, STC fitting, injector o-rings, or standpipes.
so do you think the problem I am running into Is I'm not getting enough oil pressure and that's causing the truck not to start.
Your not giving bismic anything to help you out. He’s one one of the top guys on here. I highly respect his opinion. BUT with no info it’s like Wedge said get out my crystal ball. Help him help you.
