No Fuel pressure
Old Oct 15, 2013 | 06:09 PM
DrFord's Avatar
DrFord
No Fuel pressure
Ok. 1988 4.9L EFI.
The truck has sat for the better part of the last 3-5 years. Just driven every few months. Recently it has begun running pretty badly. felt like a fuel starvation issue. I found the FPR was bad and changed it. (fuel was coming through vacuum line) that helped a little but not 100%.
Well now the truck will not start at all. I pulled the fuel line off on the front side (before) of the fuel filter. Very little ran out of it. I left it open and cycled the key several times. I can hear the pump turn on for about 2 seconds with the key, but no fuel comes from the line. I tried switching between front and rear tanks with same results. although when I switch to front tank the sound of the pump is different. but the results are the same. No fuel. The front tank reads fuel in it. the rear one should have a little bit in it from this summer. The sending unit shows empty on anything under 1/4 tank. been like that for many years.
So where Is a good place to start looking? any ways to manually turn pumps on to verify they are or are not pumping.
Thanks
Old Oct 18, 2013 | 10:09 AM
AbandonedBronco's Avatar
AbandonedBronco
Have you checked to see if maybe the fuel filters are just plugged? They may be filled with junk from sitting for so long. Fuel filters can plug bad enough that they can require vehicles to be towed home.
Old Oct 18, 2013 | 02:59 PM
dustybumpers's Avatar
dustybumpers
There are 2 pumps on your truck.
One in the tank (s), One in the frame rail
The tank pump is a lift pump, low pressure
The pump in the rail is the high pressure pump
Make sure all pumps are working
Another problem is the fuel reserve transfer
That's the can looking thing by the fuel pump. It has 4 lines in, from the two tanks, and 2 lines out.
It's purpose is to return the fuel to the tank it is being pumped from.
When they fail, you will get no fuel to the engine, no matter what tank your on. All pumps work, but cannot supply fuel, because it's cut off
Old Oct 20, 2013 | 12:18 AM
Big Norm's Avatar
Big Norm
Fuel pump is bad
I will almost guarantee that if your fuel filter is not plugged then your fuel pump is bad. I played that game mid summer and finally replaced my in tank fuel pump on my 1992 F250 300 4.9 and it started and ran like a dream.
Old Oct 20, 2013 | 12:19 AM
Skip1970's Avatar
Skip1970
what year did they start fuel injection on the inline 6?
Old Oct 20, 2013 | 01:22 AM
Big Norm's Avatar
Big Norm
Fuel injection
Look it up on Wikipedia. Believe it or not. They have the most straight to the point history of the entire 300 motor evolution. It's really quite informative
Old Oct 20, 2013 | 08:47 AM
rikard's Avatar
rikard
!987 was the first year of EFI for the F series.
Old Oct 20, 2013 | 09:46 AM
dustybumpers
Starting in 90, the fuel ststem went to 1 fuel pump (2 if 2 tanks)
This is a high pressure pump called a fuel delivery module.
85 - 89 had the older system.
The fuel transfer reserve can is his problem. You do not have this on your 92.
JD Gimpl
Jun 14, 2012 09:36 PM
dhutchinson90
Dec 20, 2010 06:17 PM
bobgretzky
Dec 29, 2008 06:32 PM
DJdemon6696
Nov 19, 2008 12:08 PM
302 F-150
Aug 28, 2007 03:14 PM
