Bad IPR or Failing hpop??
Hey guys I have been watching my icp and noticed that it seems low under WOT. I have been suspecting their might be something going on with the IPR but am unsure. ICP seems fine AT idle, between 550-585. If I am going through the gears at about 3/4 throttle, ICP seems well between 2700-2900 , and sometimes hits 3000 psi. If I get all the way into the pedal it drops all the way down to 2100-2300 and does not recoup until I back off the throttle a little. Does this seem normal? I usually run a 80hp tune so these aren't stock numbers. I have read In the past that it is rare for the hoop to fail on these so that's why I was leaning toward the IPR. Been wanting to try a new IPR but don't want to waste money. Also wanted to add that I have replaced hpop lines and stc fittings to non check valve fittings. Another reason I was wanting to try a IPR is I can't figure out my rough idle issue. My ICP numbers usually stay pretty tight but I have noticed them drop down to 480-500 abruptly, but rarely. What do you guys think, am i on the right track or out in left field?
dp tuner, not sure on fipw, it usually happens to fast. O rings are only 6 months old. Going to try the cody test again
Exact same scenario I was going through. Read through this thread. Your FIPW is going to high and causing ICP to tank. I have tried two different tuners and am still not happy with the tunes but it is on the back burner for now.
https://www.ford-trucks.com/forums/1...p-or-tune.html
DP. Id yank that off my ECM in a heartbeat to see what stock tells you with the numbers. If it fixes it then Id suspect the toons first or bad contact w chip second. Id not buy a HPOP until Id tried everthing else. To manyh dudes here have fell for that BS and wasted $$$ on a high dollar bandaid. I had a issue similar and as it turns out was teh toons all along. kletus was right as usuall.
Jo7.3
08-20-2017 04:53 PM
JonathanN
09-29-2010 05:41 AM
