CPS replacement
Old Jan 13, 2018 | 11:11 AM
GA_Boy's Avatar
GA_Boy
CPS replacement
2001 F250, 7.3 2 wheel drive.
What tools are needed to replace new CPS? I carry a spare but forgot what tools to take other than a throw rug and flashlight.
Thanks, Marvin
PS, I bought a new Gray one from ford. 31dollars.
Old Jan 13, 2018 | 01:49 PM
MR KROGOTH's Avatar
MR KROGOTH
Thanks, Marvin
Wrong forum, but a 10mm box end wrench or socket w/ratchet usually does the trick.
Old Jan 14, 2018 | 09:30 AM
timmyboy76's Avatar
timmyboy76
OP... Your in the right forum. 10mm socket with 3in extension. Just replaced mine
Old Jan 14, 2018 | 11:21 AM
Colorado350's Avatar
Colorado350
Thanks, Marvin
I'm guessing someone moved your thread for you. 10mm socket.
Old Jan 14, 2018 | 11:28 AM
MR KROGOTH's Avatar
MR KROGOTH
it was originally in the IDI forums.
Old Jan 14, 2018 | 05:49 PM
GA_Boy's Avatar
GA_Boy
Thanks everyone. I guess I posted in the wrong forum at first.
Marvin
Old Jan 15, 2018 | 08:36 PM
Supercab's Avatar
Supercab
Don't you need a small screwdriver to pry the old one out with?
Old Jan 16, 2018 | 11:10 AM
hydro man 17's Avatar
hydro man 17
"Don't you need a small screwdriver to pry the old one out with?"
I didn't need to. It's just an O-ring on the sensor and the hold down bracket of course. If it's caked with grease/dirt - ??
Old Jan 16, 2018 | 11:25 AM
BillyBob69's Avatar
BillyBob69
What they said ^^^^
I keep a box wrench and a small screwdriver to help it get past the o-ring indent. I also use the screw driver to help pry a little to disconnect the harness.
Old Jan 16, 2018 | 12:10 PM
brian42's Avatar
brian42
Veteran: Navy
The bracket pivots so you should be able to start the sensor out by pulling on the bracket. A screwdriver can be handy for the connector especially if the block is hot. I try to only use my hands on the sensor so I don't damage anything removing or installing.
Old Jan 16, 2018 | 07:26 PM
GA_Boy's Avatar
GA_Boy
I got it now, thanks everyone.
Marvin
Nader
23
Oct 8, 2015 08:12 AM
aocabrown
Nov 12, 2007 10:28 PM
Kookadala
Mar 21, 2007 11:12 AM
blhfla
May 13, 2006 01:28 AM
