92 f-150 wont start
Old 01-15-2018, 07:41 PM
Smokin 6.9's Avatar
Smokin 6.9
Smokin 6.9 is offline
92 f-150 wont start
Just got a 92 f-150 for $350, replaced everything it needed cleaned fuel tanks replaced both fuel pumps. The truck seems to have been running worse taking a while to start loping at idle when cold. About a week ago I started the truck and unplugged the iac while it was running and it stopped
right away. Plugged it back in and tried to start it would only fire once in a while wouldnt start. Both fuel pumps work, so could the filter be plugged and not letting enough fuel get to the rail? And also what could my idle problem be? When it ran it had a hunting idle and when you revved it it would almost stall go back up almost stall again and so on until it finally smoothed out. The engine light comes on once in a while when driving and goes off until the last time I drove it it stayed on until I shut it off. Havent had a chance to try reading the codes. Thanks for any help
Old 01-15-2018, 08:45 PM
phoskins's Avatar
phoskins
phoskins is offline
Definitely replace the fuel filter since it shouldn't be difficult. Then, you might check fuel pressure using a gauge on the Shrader valve, located on the fuel rail under the hood. Clean the IAC. Check/replace spark plugs? Check distributor timing? Not sure what else you should do from there.
Old 01-16-2018, 11:21 AM
'89F2urd's Avatar
'89F2urd
'89F2urd is offline
Pull codes and check fuel pressure. Also see if it will run on ether to confirm that it's a fuel problem or ignition problem. Doesn't ever hurt to replace a fuel filter.
Old 01-17-2018, 07:34 PM
Smokin 6.9's Avatar
Smokin 6.9
UPDATE
so i pulled codes 114 116 and 636 and i replaced the fuel filter and checked the fuel pressure and it was between 38-40. Didnt try to start on ether. I also put a different iac on that i know works and no difference.
Old 01-17-2018, 08:38 PM
88XLTLariat's Avatar
88XLTLariat
88XLTLariat is offline
PIP failure. Try a new distributor, plugs, wires, etc. When is the last time it had a nice tune up?
Old 01-17-2018, 09:53 PM
Smokin 6.9's Avatar
Smokin 6.9
Havent tuned it up since I bought it due to other things like column front end fuek tank ext, I wanted to get it to run before I did a full service of the motor
Old 01-17-2018, 09:55 PM
Smokin 6.9's Avatar
Smokin 6.9
Havent tuned it since I bought it because Ive been fixing all of the other peobkems like front end, fuel tanks, column, shocks, transmission ect. Do you think an msd distributor and coil plus msd wires and new plugs would do the trick?
Old 01-17-2018, 10:44 PM
88XLTLariat
I'd stick with Motorcraft parts, if you can. They are a little more expensive, but worth it. Just be aware that some of the cheaper distributors are refurbished (new plastics, new gear, etc.) but the PIP goes untouched. Make sure you get new and not rebuilt.
Old 01-23-2018, 12:51 PM
Smokin 6.9's Avatar
Smokin 6.9
I replaced the Iac and the pickup in the distributor and still nothing. Still wont fire on ether or gas and has the correct fuel pressure. Im stumped! Could it be the map or the maf? It also has strong spark.
Old 01-24-2018, 05:33 AM
'89F2urd's Avatar
'89F2urd
'89F2urd is offline
Have you checked the computer?
If it won't run on ether, then you have an ignition problem.
Timbart1
03-10-2019 02:01 PM
rcamsler
Modular V10 (6.8l)
07-19-2010 03:38 PM
mattyz426
08-18-2009 05:45 PM
egalaxie
10-27-2008 10:37 PM
irishguyincc
1983 - 2012 Ranger & B-Series
29
08-18-2005 12:20 AM
Quick Reply: 92 f-150 wont start
