Driveability
Old Aug 13, 2009 | 05:22 PM
mattyz426's Avatar
mattyz426
Driveability
I have a 1996 F150 it has started to have issues after it has been driven for awhile and I shut it off for 10-20 minutes and restart it it will sputter and then run ok.The last couple of nights I have gone up to cut a load of wood if I let it sit for a few minutes and idle it will start to sputter and die. I will crank it and it tries to fire off but doesnt.The longer it sits the easier it will start. If it sits overnight it starts fine. I pulled the codes and there was none stored in the computer.
Old Aug 13, 2009 | 06:24 PM
Cobra Highboy's Avatar
Cobra Highboy
Try changing the fuel filter, if it is clogged it will cause low fuel pressure and at idle the pressure will be way low. hope it helps.
Old Aug 13, 2009 | 06:39 PM
Sportruk's Avatar
Sportruk
When it's difficult to start, try pressing the gas pedal down a bit. If it fires right up, it could be a bad Idle Air Control valve (IAC).
Old Aug 13, 2009 | 09:40 PM
fivepointohno's Avatar
fivepointohno
sounds like classic signs of a half cloged fuel filter
Old Aug 14, 2009 | 10:42 AM
mstngmikegt's Avatar
mstngmikegt
While I agree that replacing the fuel filter may cure your ills (and if not, is good preventative regular maintenance so no harm done), these comments make me suspect the ignition system since the problem appears to be heat related.
My first thought is TFI (Thin Film Ignition) module. Routine weak point in Fords and subject to heat-soak failure (so much so that they finally removed it from the distributor itself and put it in it's own heat sink...driver's side rear fenderwell mounted IIRC on your truck). The revised mounting helps keep them alive, but they are still the same weak part so they still go bad. Also, I don't believe they will throw a code when they start to go bad.
My suggestion would be to start with the fuel filter (again, not a bad idea even as maintenance) then if problem persists or gets worse, look hard at the TFI module. Some parts stores can check them, but again, they act up when hot, so bench test cold doesn't really tell the whole story though. Unfortunately, they seem to continue to act up when hot then they just die though so there is no prior notice of total failure (except that it will surely occur when it is most inconvenient.)
Good luck!
Old Aug 14, 2009 | 11:15 AM
DBGrif91's Avatar
DBGrif91
I'd have to agree with mikegt here- I'd suspect ignition system. The TFI module isn't a bad idea, but you might also want to check out your coil too- the fact that the longer it sits the easier it starts tells me that's because your coil is cooling down.
When's the last time you checked your spark plugs as well? I'd also pull them all and see what they look like- the plugs can be a good indicator of what's happening not only inside the combustion chamber but also with the ignition system itself. If they look normal, then next time it's acting up, check the color of the spark. I believe that white is a hot spark and blue is a cooler spark, but someone else may want to confirm that.
You may also want to pop off the distributor cap and check the contacts and rotor for carbon build up.
Just some ideas. Keep us updated.
Old Aug 18, 2009 | 05:45 PM
mattyz426's Avatar
mattyz426
Already replaced the fuel filter it didnt help I had the same problem last summer This past saturday I wnet up to cut a load of wood and it ran fine,but it was 30 degrees out and snowing
Smirks90
13
Oct 31, 2014 06:11 PM
BigThirsy86
Aug 19, 2012 04:40 PM
CaptMorgan
May 23, 2010 05:32 PM
