P2200
Old Jan 15, 2018 | 06:41 PM
Dannyboytn's Avatar
Dannyboytn
P2200
im new to the diesel world and new to Ford, we’ll almost.. I had a 1974 Pinto when I was in college! So, I bought a 2017 just 2 weeks ago and yesterday I got a check engine light. The code I got was P2200. After reading so internet stuff, it seems to be a catalytic converters. Anyone else run into this MIL code? I’m taking it in this Thursday to the dealership. Thanks!
Old Jan 15, 2018 | 06:47 PM
stewy604's Avatar
stewy604
Seems to be a possible known issue. From what I can see, its a faulty NOx sensor.
Old Jan 15, 2018 | 11:19 PM
Fireferg73's Avatar
Fireferg73
Look for chaffed wires on that Nox sensor where it may have rubbed on the foil covered Def line.
Look at the rear sensor, there are two. The one you want to look at is the one right where the Def injector is on the DPF.
Old Jan 16, 2018 | 12:49 PM
jaxf250's Avatar
jaxf250
Did you guys watch this yet? I am going to check all my wiring this weekend and make sure it is not chafing anywhere:
Old Jan 22, 2018 | 04:51 PM
jaxf250's Avatar
jaxf250
After watching that video I found one wire harness that definitely would be rubbing on the underside of the truck over time, and put some heavy plastic loom all around it to protect it. I also found a couple other wires that look like they could use it as well just to be on the safe side, since I had some extra Loom leftover I didn't want to let it go to waste. It got too dark outside to take pictures, but it's pretty easy after watching that video to identify where you might want to do a little preventive maintenance on these trucks.
Old Jan 22, 2018 | 05:22 PM
Harry500's Avatar
Harry500
The chafe protection on the sensor wires looked like it might be made for high temperature installations. I have used regular wire loom before, but does anyone have a source for high temp chafe protection?
Old Jan 22, 2018 | 06:50 PM
6.2caribou's Avatar
6.2caribou
I have a bunch of high temp woven fiberglass sheathing that we used to shield the high temp wiring on the barrels of plastic injection molding machines. It could lay directly on a 480v electric heater band. But none of the diameters that we used were over 3/4"...so it probably couldn't be used as it likely wouldn't fit iver the connectors.
Old Jan 22, 2018 | 07:52 PM
Dannyboytn's Avatar
Dannyboytn
Thanks for the tips about the chafing of the wires. I’m going to put some looms on these wires. Also the dealer replaced the NOx sensor.
air1jpg
2004 - 2008 F150
Feb 19, 2014 09:22 PM
blustang6614
Oct 12, 2013 10:19 AM
aphotic26
6.4L Power Stroke Diesel
18
Aug 30, 2013 05:15 PM
undertow91
Feb 19, 2010 10:31 PM
Storm
3.8 & 4.2L V6
May 13, 2006 02:55 PM
