crash sensor
Old Feb 18, 2010 | 06:39 PM
undertow91's Avatar
undertow91
crash sensor
My 99 expedition is flashing a 41 airbag code. After some googling, I think this is for the right front crash sensor. I'm looking for some confirmation on that from someone and some troubleshooting procedures. I've measured resistance between the connector pin and the metal casing and got 1.5 k-ohms on the right side and 1.1 M-ohms on the left. So I'm pretty sure I have a bad sensor, just want to confirm which one. Also, the rust up in that area is pretty bad so I'm wondering if its just a bad ground connection. Any help would be appreciated.
-Pat
Old Feb 18, 2010 | 07:39 PM
fordtech08's Avatar
fordtech08
well the resistance needs to be between 1,530 and 1,630 ohms otherwise it's a bad sensor, and yeah definetley check your ground since that is where you are measureing between
Old Feb 19, 2010 | 10:23 AM
undertow91's Avatar
undertow91
ok so from what you said my right sensor measures the correct resistance, but my left has really high resistance. So it seems my left front sensor is suspect, but I thought code 41 was for a right front. Can someone confirm which side a code 41 is for?
Thanks
Pat
Old Feb 19, 2010 | 12:18 PM
fordtech08's Avatar
fordtech08
exterior sensor is what the code says
Old Feb 19, 2010 | 08:03 PM
undertow91's Avatar
undertow91
thanks for the info. I ended up replacing the left sensor and it fixed the problem.
Old Feb 19, 2010 | 10:31 PM
fordtech08's Avatar
fordtech08
glad it worked for you
JTHill24
Aerostar
Feb 2, 2017 09:55 AM
RideDiesel88
Feb 6, 2015 05:08 PM
HungOverSheep
27
Jul 25, 2014 08:45 AM
The Ride
Jan 17, 2014 12:36 PM
