Is This Normal? Voltmeter Reading...
Old Jan 14, 2018 | 09:48 AM
Jonnyuma's Avatar
Jonnyuma
I know these aren't "real" gauges, so I'm wondering if it's the gauge, a stepper motor, or if I really have an issue... or maybe it's normal...
The needle sits on the "L" of "Normal" all the time. It's not stuck there, it zeroes out when the ignition is turned off. My MM is packed-up somewhere (moving) so I'm wondering if I need to dig it out, or just let it go.
Old Jan 14, 2018 | 09:52 AM
Red97350's Avatar
Red97350
I would dig out the meter to double check. I guess you could also bring it to a place that checks batteries and alternators.
Red
Old Jan 14, 2018 | 10:05 AM
Jonnyuma's Avatar
Jonnyuma
Red
You're probably right... I dread the thought of digging through boxes of garage crap more than anything. I think I'd rather just go buy another MultiMeter.
Are these gauges fairly accurate? It looks to be charging @ 15V or so, ALL THE TIME. What's the normal charge rate on these trucks (93 F150, 4.9) given a good battery? Any good advice on testing the voltage regulator (assuming it's a possible culprit)?
Although it's still in the "Normal" range, if the gauge is accurate, that seems to be working the alternator pretty hard.
Old Jan 14, 2018 | 11:07 AM
DrCharles's Avatar
DrCharles
Remember that in cold weather, a battery takes a higher voltage to charge. What's your temp these days?
No, those gauges are not particularly accurate. Buy a cheap DVM, you can get reasonably accurate ones (at least for DC Volts) at Harbor Freight and other places. Or borrow a better one.
First thing is to find out what the actual voltage is at the battery posts. Then go from there.
Old Jan 14, 2018 | 11:13 AM
Tedster9's Avatar
Tedster9
Measure charging voltage directly at battery posts. Ballpark is 13.8-14.3, turn on headlights and radio, heater blower fan etc, to load up alternator and spool up engine RPM to 1500 or so. Charging voltage should stay in the zone. Yes also keep in mind cold weather means higher numbers are required.
Old Jan 14, 2018 | 11:25 AM
mrollings53's Avatar
mrollings53
Hate to break it to you, but those are "real" gauges. Even the oil pressure gauge is a real gauge, Ford just turns it into a glorified idiot light by installing an oil pressure switch instead of a proper sender. Install an oil pressure sender, short the resistor on the back of the cluster, and swap the face plates with ones that have calibrated numbers on them; and you've got gauges that are just as good as anything you'd get from Autometer.
Old Jan 14, 2018 | 12:54 PM
Wheelman55's Avatar
Wheelman55
Is this a new development for your truck?
When I replaced the alternator in my '93 F250 7.5l, the needle went to the right of the battery icon. With the old alternator the needle was on the left of the battery.
My multimeter reads 14.3v at the alternator.
Old Jan 16, 2018 | 04:39 PM
TexasGuy001's Avatar
TexasGuy001
My gauge usually stays on the M. Has yours just started reading a bit higher or has it always read that?
Old Jan 17, 2018 | 05:17 PM
Jonnyuma's Avatar
Jonnyuma
It's not a new thing, but I've only had the truck for like, 6 mos. I've thought that I could smell "battery smell" a few times last fall (when it was warmer)... you know the smell. Kind of a metallic, coppery smell... the smell that's on your hands after you work on a battery.
I'll dig out the MM and check it. But if the charge rate IS high, whats the fix? Regulator?
Thanks for the help. I really do appreciate it... just got busy w work so I couldn't tend to my own thread. Got another b*tch of a week ahead of me. I love OT but... daaaamn.
Old Jan 17, 2018 | 06:17 PM
Tedster9's Avatar
Tedster9
You could take to the 'Zone or that Irish parts store, most of them will test batteries and charging systems for free.
Do the headlights or dash lights change brightness depending on engine RPM, anything like that? Overcharging is not good, another simple check is to install a voltmeter in the cigar lighter receptacle.
Old Jan 17, 2018 | 06:38 PM
Wheelman55's Avatar
Wheelman55
Originally Posted by Tedster9
...another simple check is to install a voltmeter in the cigar lighter receptacle.
Those plug in voltmeters are surprisingly accurate.
Old Jan 23, 2018 | 03:52 PM
Jonnyuma's Avatar
Jonnyuma
I picked up a plug-in DVM and watched it the other night on the way to work... about 5 miles, 15-20 min depending on if I catch all the red lights.
Started at 14.3V w engine running, lights on, defroster running w fan on low. It dropped 1/10th at a time and finished @ 13.9V when I shut it off. 12.8 V at rest.
Seems pretty normal to me. What say you?
Old Jan 23, 2018 | 04:17 PM
Tedster9's Avatar
Tedster9
Sounds about right - keep in mind that for accuracy measurement at the battery posts is preferred. Might see a 1/2 volt difference/error, which is quite a lot when it comes to batteries and charging. Depending on battery state of charge and temperature somewhere around and between 13 to 15 volts is normal and necessary and righteous. Numbers sound real good.
Old Jan 23, 2018 | 04:47 PM
Red97350's Avatar
Red97350
I would say that is good. I would keep checking it occasionally. I certainly wouldn't say that it's high.
Red
F150Dad
1997 - 2003 F150
Dec 6, 2015 11:05 AM
Fordranchero
Apr 22, 2011 08:47 AM
Mydiesel250
15
Jan 22, 2011 08:31 PM
sadie's 250
16
Dec 10, 2010 09:55 AM
1mtr23
1983 - 2012 Ranger & B-Series
Oct 28, 2007 04:25 PM
