Strange charging problem
Old Apr 21, 2011 | 04:59 PM
Fordranchero's Avatar
Fordranchero
Lately my 92 7.3 ide has developed an odd thing, after first starting up the voltage gauge drops almost to bottom, sits there for maybe 15 seconds then does the usual few jumps as the gp cycles, evens out at a lower voltage and slowly rises to normal.
The occasional time it does not move or come up at all.
I have check all plugs and connection on alternator and batteries.
What else?
Old Apr 21, 2011 | 07:28 PM
85grey's Avatar
85grey
If it always starts good and cranks fast I would GUESS that the gauge is not working properly. If you have a volt meter, check how many volts it has after startup. it should have 13 to 14.5 volts when charging. If it is in that range than the first thing to check is the battery connections.
Old Apr 21, 2011 | 07:38 PM
1994F2507.3L's Avatar
1994F2507.3L
i bought a three gauge set from orielly came with oil pressure, water temp, and voltage. i would suggest you do the same.
i would check it with a voltmeter just to be on the safe side but defiantly ditch those stock gauges
Old Apr 21, 2011 | 08:06 PM
Fordranchero
I have a new 3 gauge set I will put on tomorrow.
I seem to be hearing that these stock gauges are even crappier than the usual?
oreocreaming's Avatar
oreocreaming
put a test light on your glow plugs to make sure they arent staying on causing that draw in amps. your gpc can go bad and cause them to stay on. that would be my first check
Old Apr 21, 2011 | 10:37 PM
Fordranchero
Actually that thought had crossed my mind but I put a new controller on less than 20,000 miles ago but who knows? It almost acts that way.
Old Apr 21, 2011 | 11:02 PM
oreocreaming
its worth a look
Old Apr 22, 2011 | 08:21 AM
1994F2507.3L
just remember there is a afterglow and the plugs can go on and off for up to i think 2 minutes
Old Apr 22, 2011 | 08:47 AM
Fordranchero
I'm aware of that, I've owned several diesels, this is different, it's a hesitation to come up on the gauge.
jayro88
15
Oct 8, 2014 05:16 PM
bruno2
Mar 1, 2014 04:05 AM
creator
Feb 7, 2012 11:53 AM
fordpride
Oct 7, 2011 08:58 PM
njstevens
Aug 28, 2010 11:46 AM
