battery voltage
Old Oct 22, 2007 | 03:04 PM
1mtr23's Avatar
1mtr23
battery voltage
This morning when I got in my truck I noticed the gauge was a little higher than before. I checked it with a multi-meter and it read 14.75 with it running. The gauge is not to the red mark but do you think there is something to worry about or should i just let it go? It usually is on the high side but seemed higher today.
Old Oct 22, 2007 | 03:44 PM
chuckbrodeur's Avatar
chuckbrodeur
I'm not sure what the nominal charge voltage is from a ford alternator but I think between 13 and 15 volts is reasonable.
Old Oct 22, 2007 | 03:56 PM
1mtr23's Avatar
1mtr23
This is the factory alternator from '93 so Im just waiting for it to go out. I dont know what its supposed to charge at either thats why I posted.
Old Oct 22, 2007 | 06:54 PM
sfcwoodret's Avatar
sfcwoodret
Check and make sure the Battery is holding the proper charge. It may have a cell going bad.
Old Oct 23, 2007 | 10:15 AM
1mtr23's Avatar
1mtr23
I replaced the battery last month but just because its new doesent mean anything I'll check it.
Old Oct 26, 2007 | 02:29 PM
XLTDAWG's Avatar
XLTDAWG
I've noticed the same thing on my '92 Ranger V6. The gauge on the instrument panel always shows it's higher than 12 volts so I checked the battery with a multimeter also and it came back as 14.30 volts. I've had this truck since new and have not had any charging problems with it except a few years ago I replaced the alternator with a rebuilt one because the gauge was showing a "flickering" of the needle when idling. Since changing it out that problem has gone away so it's obvious the alternator was dying, but the 14.++ charging volts seem to be the norm on these systems.
Old Oct 28, 2007 | 04:25 PM
1mtr23's Avatar
1mtr23
I found out the safe range was 13 to 15 volts so I am just going to watch it.
