Ranger Revealed!
hyundai start making a truck already? i was hearing they were gonna start building 3 cylinder diesel versions
My Ex is still driving the 2014 Subaru Forester XT that I bought new....Subaru screwed it up with some update that was eventually corrected. 84,000 miles and it runs fine. I guess thats all the proof I need.
Water pumps don't fail often, but as an old guy who changed water pumps in under an hour in 1960's cars (with a $15 rebuilt pump), the new engines are a PITA.
Haha, No. I fall into the city boy wants a truck he dose not need category. I find myself looking at many different brands and models.
The new 3.5 and 2.7 Ecoboosts (non transverse applications) do have port injectors as well as DI, which is a Toyota system to both reduce emissions (better fuel atomizing at idle) and to clean backs of intake valves.
But there are DI-only 2011 Eboosts with over 200k miles on them that have had no problem with carbon deposits. (I'm a Subaru fan also and their current 2.0 DI Turbo DOES seem to have the intake valve carbon problems, so I have no illusion that this is no longer a problem...)
So 2 things make me feel better--Ford has a good history with no major carbon buildup problems with DI only, and as they revise their Eboosts into the next gen, they seem to be adding secondary port injection....although the first year Ranger 2.3EB may not be one of the engines to benefit from this.
For what it's worth, I have looked at Edges and Explorers with the 3.5 normally aspirated engine and the 2.7 and 3.5 Ecoboosts and THEY scare me because it costs 2 grand(!?) to replace a water pump (internally driven by the cam chains and inside the valley), and there have been people who have bricked engines when water pumps have failed. Not a problem with non-transverse engines, but I'd take a 4 cyl EB in an Edge or Explorer and take my chances with intake valve carbon over the prospect of a blown up water pump.
It's always something...my '02 E150 needed new cylinder heads on the Romeo 4.6 because of the bad design of the early Romeo PI heads. Covered by warranty... And then the history of shooting out spark plugs, sticking plugs in 3V heads, etc. I am hoping all of those cyl head engineers are retired by now.
timing belts are easier and cheaper
cartridge filters also annoy me too
And the cartridge oil filters are wonderful. ZERO mess and no lying on your back trying to maneuver a filter wrench up into the engine bay.
depending on where the cartridge oil filter is located, i.e. underneath its messier and more time consuming than a spin on filter.
also twice the price.
The 2.3 EBoost has more horsepower and way more torque at lower RPM than its competitors' V6's... (In the Explorer, the 2.3 EB is an upcharge from the base 3.5 V6.)
Ford is doing power with turbos...
I get that Ford is doing big power with their turbocharged engines, I just prefer a naturally aspirated engine. Typically they are more reliable and need less maintenance. Turbos can get real finicky on what type of fuel you can use in them, what type of oil you can use, coolant, etc... Also with a small turbo-4, the only time it's going to get really good fuel economy is when you're not using any boost at all. As soon as you allow the boost to come on, your fuel economy plummets to about that of an old V8! A naturally aspirated V6 can do comparable power more consistently, without huge differences in fuel economy. I like the Ranger, but I will cross-shop it against the Colorado or Frontier; which both offer a naturally aspirated V6.
If I was a fleet buyer, I would avoid the 2.3 EB/ten speed combo. You don't want to put your drivers in anything other than the least expensive drive train.
My Dad, at 79, still sells trucks everyday. They have zero info on the Ranger other than press releases. He used to sell a lot of fleet models. Lots of companies use smaller trucks. I saw an Orkin Tacoma the other day.
He sells a lot of gas Super Duties to fleet customers. Drivers abuse the trucks and the new DPF diesels aren't exactly bullet proof. Accidentally putting diesel in a DEF or vice versa costs $15-18k. The Ranger will need a simple base drivetrain unless Ford isn't going for the fleet market.
If the new Ranger is tough, I'm sure some will wind up in the oil patch as supervisor trucks or similar light use. The suspensions take a major beating. Modern cars don't last.
We'll see soon enough if they last in the Eagle Ford, Permian Basin, North Dakota or the strip mines of Wyoming. My dad has a saying about oil field trucks; When they go into the oil patch they never come back. Which is to say they get used and used until they're junk, not traded in.
From what I've seen of the global Ranger, it looks like the toughest truck of it's size on the market. Let's hope the frame and suspension haven't been modified too much.
