6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Bluetooth Support
Old Jan 13, 2018 | 10:51 PM
Wall.e's Avatar
Wall.e
Bluetooth Support
2008 Ford F350 SD SRW 4x4 Second owner bought from Dealer. They never offered Bluetooth on this stock radio.
Single CD AM/FM with Sirrus XM Aux port, has phone mute button. Vehicle dose not have Bluetooth available in truck, no steering wheel buttons or ceiling mic.
Crutchfield Tech's told me that steering wheel seek up/down buttons acts as answer and hang up on phone calls.
Please Advise.
Old Jan 14, 2018 | 07:01 AM
73F700's Avatar
73F700
Not really clear what the question is.
You are correct, your truck does not have Bluetooth in the stock headunit. Some have added Bluetooth to the stock unit using the aux input and a device that communicates with your phone. This works fine as long as the headunit is left on in the AUX mode.
If you are considering a aftermarket unit from Crutchfield, then you will need to rely on their tech support for that particular unit. If you know the make and model of the unit you could post it in the audio forum and likely get some help there.
Old Jan 14, 2018 | 09:00 AM
Copper.Farm's Avatar
Copper.Farm
Old Jan 14, 2018 | 09:05 AM
MisterCMK's Avatar
MisterCMK
Same here, it stays plugged into the aux port in the work Truck.
blowhole
Sep 20, 2023 10:55 PM
cubangt
Jan 17, 2015 03:28 PM
VolvDL
13
Jan 21, 2011 09:35 AM
Irish Wake
Nov 25, 2010 06:42 PM
PSDmike
Oct 5, 2006 04:37 PM
