Turbo shaft worn?
Old 01-13-2018, 07:38 PM
kameronth's Avatar
kameronth
kameronth is offline
Turbo shaft worn?
I've got my turbo pulled apart and the shaft has some slight possible wear marks. Is this normal/okay to use or do I need to order a new shaft?
Old 01-13-2018, 08:05 PM
kameronth's Avatar
kameronth
I just discovered that my center section is cracked, so I'm just going to break down and order a new center and shaft.
Old 01-13-2018, 08:49 PM
97-psd's Avatar
97-psd
97-psd is offline
Sorry to hear that. What made you pull it apart?
Old 01-13-2018, 10:38 PM
kameronth's Avatar
kameronth
When I purchased the truck I noticed the compressor wheel blades were damaged so I purchased a new compressor wheel from SP. And as usual one thing turned into another and I went a little over board ordering parts for preventative maintenance since I pulled the turbo and had it all apart anyways. A new wheel has turned into:Turbo rebuild kitTurbo center and shaftEBPV delete pedestal Fuel pump and fuel lines(the banjo bolt only had one washer... hence the fuel leak I found while I was pulling the turbo)Glow plugs( had Bosch’s - changing to Motorcraft)Glow plug solenoid (White Rodgers)Valve cover gaskets and wiring harnesses Up pipe donutsY-boot set
Old 01-14-2018, 10:15 AM
z31freakify's Avatar
z31freakify
z31freakify is offline
Received 1,191 Likes on 817 Posts
Man if you consider keeping your turbo do the Freakify mod, you will be glad you did when it comes to removal.
Old 01-14-2018, 10:41 AM
kameronth's Avatar
kameronth
I probably should’ve went that route but I already have the parts and parts on order to replace the original stuff. I actually didn’t find the turbo too difficult to remove and had it out in an hour and a half. My truck has very little rust so I’m sure that helped too.
Markus Luukko
04-10-2018 02:07 PM
JGRNAUT_7.3L
25
12-11-2017 09:45 AM
dieselsubmariner
04-09-2016 08:22 AM
79'F-250_Guy
07-31-2013 07:06 AM
1997F-350
05-08-2005 11:27 AM
Quick Reply: Turbo shaft worn?
