Turbo wheel toast?
Compressor side is fine. Bearings look ok as well. Definitely had a blown turbine end seal though from the looks of it with all the build up. Could that do it? I’m just damn glad I decided to put the whicked wheel in and rebuild the turbo while I was in there. I’m thinking this could of gone real wrong very quickly. Didn’t have a clue it was messed up. Guess I’m packing up for the night and ordering parts in the morning. 😔 Another speed bump in this maintenance/upgrade weekend. Guess I rather find it this way then a loud explosion and be stuck on side of road.
Ya I was in doing billet plenums, bellowed uppies, whicked wheel 2, ebpv delete pedastal and housing, and fuel bowl rebuild. So it should be a whole new truck when I get it back together. Let alone having this problem and not even knowing it. Can’t wait to stomp on the skinny pedal now when I’m done 😬.
Between what happened to the exhaust wheel and the compressor side, you had likely had a bad thrust bearing. Unfortunately, you probably need a center housing cartridge as well. That exhaust wheel was right up against the heat shield/bearing housing surface. You probably damaged the oil seal groove in the housing. I also would not reuse the compressor housing if it is grooved. Basically, you need a whole 'nother turbo to build. By the time you buy all the parts to fix what you have, it would be cheaper to find another core, just in need of a rebuild, but not toast like yours.
So what turbo are you going to get? The KC Turbo is perpetually out of stock on the site, but maybe you can call them?
Suggestions, guys? He needs the good and the bad quickly. Probably has been concentrating on all the other stuff, so let's share the research and opinions
http://www.dieselsite.com/dieselsite...acement-1.aspx The 3" version is on sale for $1050
The 4" inlet version:
http://www.dieselsite.com/dieselsite...lacement4.aspx
The Wicked Turbo is on sale for $1149. Price looks good, but I haven't really heard/read too much, as far as feedback from guys actually running them.
Hopefully do not need a whole new turbo and can continue with the rebuild of this one. Just need a new shaft with turbine wheel. Already have all the new bearings and stuff in the rebuild kit I had.
Your right, I do not see any grooves on the compressor side, but the wheel looks beat up a bit. Nothing like the turbine side of course, but a bit beat up none the less.
I wish I could answer your question about the center cartridge, but I just don't know. If I were in your situation, I would call SPTurbo and speak with Kevin and call RiffRaff and see if you can speak with Clay about what you are seeing, what you know and what you don't know and see where those guys recommend you go with the project.
Bump to the top for you too.
