Removing turbo- wits end
#76
Yeah as long as you’re above 40 that’s ok but i saw you mentioned it was dropping below. I run 60-65psi with my efuel setup but it was not running right st all when it was dipping into the 30psi range as the filter clogged. No smoke though just no power. At 20psi it was missing on several cylinders.
#77
#78
#79
I figured it's at least ok to drive for now until I have time this week to look into it some more. It drove even better today. Fuel preaaure is staying above 40 even at about 30-50% throttle so I'm fine for now. I was planning on buying the mark fugazzotto e fuel kit but then I bought a house so now I'm going through all that. So after I get settled in, I will be looking into doing that again.
#81
But, when it warms up it should go back to liquid. I've gelled up many times and after the vehicle warms up it runs again. On a VW Rabbit I've used a fusee on the fuel filter and have put a heater under the fuel tank. If fuel would have stayed the way it looks on that filter I would have never got going again.
#82
howellt39
05-20-2013 08:30 AM
schmuly
03-08-2008 08:39 PM
GoCamping
12-10-2006 03:26 PM
GoCamping
11-25-2006 08:24 AM
