Removing turbo- wits end - Ford Truck Enthusiasts Forums
Old 01-07-2018, 04:21 PM
B-Rad88's Avatar
B-Rad88 B-Rad88 is offline
B-Rad88 is starting off with a positive reputation.
So I previously posted about the issues I was having. Long story short, I'm pull the turbo, putting a 1.0 housing in, bypassing the EBPV, getting those 2 pieces ceramic coated, and putting a different stock turbo on that's in good shape with a new turbo wheel on it.
I'm basically about at the point where you start seriously considering just selling the truck.
I have the turbo and housing off, but can't get the back 2 pedestal bolts. The passenger rear pedestal bolt is stripped, but I don't know if one of those extractor sockets will fit on it between it and the up pipe collector. I haven't tried very hard yet on the back driver side pedest bolt, but I kind of feel I need Jesus to help me get it off.
I had to remove the turbo and housing separate because of the stripled bolt.I wanted as much access as I could have to tackle it. I have thrown everything I got at it all day and still nowhere. Tried torching it but that didnt work, but now I absolutely have to get it out because I'm sure i roasted that o ring.
Anybody in the Phoenix metro area that has more experience with this want to give me a hand? I'm waiting on parts for everything from riff raff so it will be until next weekend at the earliest before I can put it all back together. But I'm getting desperate. I did read somebody said to just cut the bolt heads off with a dremel. I'm not opposed to that as long as it works and I can get the studs out. I don't know if a dremel will fit back in by that bolt on the driver side, but I have another pedestal turbo and housing so I'm not concerned if I mess the pedestal up a little bit. One of the things I ordered was all new hardware as well.
Old 01-07-2018, 04:44 PM
Red97350 Red97350 is online now
Red97350 has a good reputation on FTE.Red97350 has a good reputation on FTE.
Can you take the up-pipes with the collector off? You're looking at more work that way, but you should have more access to the heads of the bolts. I'd be willing to give you a hand, but I'm a bit far for that.
Red
Old 01-07-2018, 04:51 PM
B-Rad88's Avatar
Quote:
Red
The first bolt I tried to loosen on the up pipe collector just spun the wrench so at least one of those is stripped too.I don't want to keep messing with it in case it really comes down to that.it would be a challenge to take the 4 bolts off for the collector too though. But that's basically how this ordeal has been going. I keep removing something to make it easier, to then find out I have to remove something else to make it easier, and over and over again. I soaked all 4 of them in a penetrate my dad sells which worked on the top 2 bolts and bottom 2 nuts on the up pipe flange to the turbo housing, so maybe tomorrow will be another story.
I'm just wondering what people have been doing throughout the years to get to them. I guarantee I'm not the only person who has been frustrated by it so I feel somebody has come up with a solution. That's how I figured out to remove the fuel pump giving me the room I needed to loosen the bolts underneath the turbo from the pedestal, so I could just pull that and leave the pedestal in.
Old 01-07-2018, 05:10 PM
z31freakify's Avatar
z31freakify z31freakify is offline
z31freakify is a name known to allz31freakify is a name known to allz31freakify is a name known to allz31freakify is a name known to allz31freakify is a name known to allz31freakify is a name known to all
Your solution is the Freakify Mod if you plan on keeping a stock turbo.
Old 01-07-2018, 05:34 PM
B-Rad88's Avatar
Quote:
So I googled that and your thread of it came up. I'm a little confused. Is this swapping the pedestal out for a SD one? I do not have a SD pedestal, just an E99 spyder. What is the center cartridge?
After doing this mod, does it somehow make it so that you can access each bolt more easily than before? My main problem is trying to get this crap out now. But if it isnt too expensive or time consuming and I can get my hands on the parts in a week or 2 tops, I may consider doing it.
Old 01-07-2018, 05:37 PM
The Freakify mod is using a SD pedestal and center cartridge so you can remove the turbo from the pedestal by removing two bolts from the top of the turbo (rather than the 4 bolts from the bottom). This is what I'm doing on my crew cab.
Red
Old 01-07-2018, 05:46 PM
B-Rad88's Avatar
Red
I'm assuming this doesn't help with the back 2 pedestal bolts having to come out again in the future. I'm wore worried about those. All of the hardware has sucked on this thing but I'm reinstalling everything with anti seize. Removing the 4 bolts from the bottom of the turbo pedestal wasn't that bad honestly with the fuel pump out. 3 of the 4 bolts are super easy to get.the 4th one is pretty close to the engine so you have to crack it loose with the box end of a wrench and a breaker bar, and then flip it around to the open end to keep turning it loose. Eventually, the head will hit the engine and you will have to lift up on the turbo and loosen it again until you get the threads all the way backed out. I shoved a pair of pliers under the turbo while I loosened it the rest of the way and then pulled the turbo right out. If I had known that was the route I was going to end up going, I could have had the turbo out in about an hour.
What I really need help with is figuring out how to get on that back pedestal bolt to take it out. I'm kind of thinking the up pipe collector has to come off but I have at least one stripped bolt on that. It's the easiest to access so hopefully the others weren't messed with and a bolt extractor socket will,work on them, if I can get on it.
Old 01-07-2018, 05:47 PM
A torch is your friend at this point.
Old 01-07-2018, 05:49 PM
I suppose you could just cut the up-pipes, but then you are going to need new up-pipes. Depending on how many miles are on your truck, you may have some leakage at the donut gaskets anyways.
Red
Old 01-07-2018, 05:50 PM
B-Rad88's Avatar
I tried a torch earlier on the stripped bolt but I think it's too stripped for anything to work. So hopefully soaking it with penetrate and then using my torch when it's dry, with an extractor socket will get that bolt out. Then I just have to come up with something for that last one.
Old 01-07-2018, 05:51 PM
You could just cut the pedestal worst case scenario, and you have another pedestal you can use.
Red
Old 01-07-2018, 05:52 PM
B-Rad88's Avatar
Red
I don't have any leakage that I know of from the up pipes. My clamp around the down pipe was pretty loose and with the turbo seals blown it was leaking oil out of that a bit.
Old 01-07-2018, 05:54 PM
I ment an actual torch to cut all of it. If you decide on the freakify mod make sure you save the turbo the pedestal can go on the scrap bin.
Old 01-07-2018, 05:55 PM
B-Rad88's Avatar
Red
I'm kind of thinking using my dremel,to cut the bolt heads off and hopefully I can get the studs out later without having to find somebody with a welder to weld nuts on them for me to get them out,
Old 01-07-2018, 05:56 PM
B-Rad88's Avatar
Probably a good thing I don't have one because I would have probably already have considered cutting through all of it since I have a replacement piece for everything I'm removing already,
Nsra northeast nationals pics mod22 1948 - 1956 F1, F100 & Larger F-Series Trucks 21 02-06-2018 06:29 AM
Build Time! dclack 1994.5 - 1997 7.3L Power Stroke Diesel 209 01-26-2018 10:31 AM
"SD bearing housing mod (Freakify Mod) z31freakify 1994.5 - 1997 7.3L Power Stroke Diesel 27 06-15-2017 10:14 AM
Turbo wear Jordo88 6.0L Power Stroke Diesel 9 05-13-2017 12:13 AM
Kindigit 55 Headlight Question richcabover55 1948 - 1956 F1, F100 & Larger F-Series Trucks 18 02-05-2017 04:43 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
