I need () to replace the headlights on my 2000 Ex. Can you recommend specific models/part numbers/links that you like or have worked for you? I'm a total newb so a complete build (ballasts? lamps? wicks & whale oil?) is very much appreciated. In descending order of importance, these are my objectives.
1. Quality
2. Quality
3. OEM fit/installation (OK to trim some header, but don't want to do a front-end conversion)
4. Easy calibration/adjustment
5. Upgraded looks/newer tech
6. Price
I went with some 02-04 style lamps from 1AAuto, at the same time I upgraded bulbs to Sylvania Silverstar's and used a Permatex Glass sealer around the new headlamp housings. Been on my 99 F250 for 5+ years now and still going strong. The are a night and day difference compared to OEM and total package was relatively inexpensive, around $120 total.
These are a aftermarket housing, Eagle Eyes if my memory is correct.
Some members use 05+ housings which require trimming if the header panel. This option is a little more expensive.
For either option you could add projectors with HID or LED for the truly best in light output. Not going to be cheap though.
