passenger front sag? - Ford Truck Enthusiasts Forums
Old 01-12-2018, 02:48 PM
marshun marshun is offline
marshun is gaining momentum as a positive member of FTE.
02 2wd 7.3
i got my new z code springs and swapped them in thinking it would even the front of my excursion. new bilsteins all around.
passenger side measures 20.5" fender to middle of hub
drivers side 21.5" fender to middle of the hub
the result is the same before and after spring swap. now im at a loss.
bushings look fine and dont have much play when i pry them.
bearings are good. passed the wiggle test but i went ahead and took them apart just to make sure.
what am i missing?
Old 01-12-2018, 08:09 PM
pirate4x4_camo's Avatar
pirate4x4_camo pirate4x4_camo is offline
pirate4x4_camo has a brilliant futurepirate4x4_camo has a brilliant futurepirate4x4_camo has a brilliant futurepirate4x4_camo has a brilliant futurepirate4x4_camo has a brilliant futurepirate4x4_camo has a brilliant futurepirate4x4_camo has a brilliant futurepirate4x4_camo has a brilliant futurepirate4x4_camo has a brilliant futurepirate4x4_camo has a brilliant futurepirate4x4_camo has a brilliant future
Quote:
Originally Posted by marshun View Post
02 2wd 7.3
what am i missing?
1. What were the old measurements ?
2. What are the measurements in the rear ?
3. Where did you get your "new springs " ?
Old 01-13-2018, 01:13 AM
1. they were the same
2. i didnt measure them.
3. fordpartsgiant.com
swapped s codes for z codes. i referenced this thread https://www.ford-trucks.com/forums/9...n-upgrade.html
Old 01-13-2018, 06:43 AM
Oldguyfl's Avatar
Oldguyfl Oldguyfl is online now
Oldguyfl has much to be proud ofOldguyfl has much to be proud ofOldguyfl has much to be proud ofOldguyfl has much to be proud ofOldguyfl has much to be proud ofOldguyfl has much to be proud ofOldguyfl has much to be proud ofOldguyfl has much to be proud ofOldguyfl has much to be proud of
Body mounts, radiator support, frame damage?
Old 01-13-2018, 09:08 AM
luisv luisv is offline
luisv is starting off with a positive reputation.
I'd measure frame to floor on a relatively level surface like a garage floor. This should be better to see if you are level.
While down there changing springs I assume the hanger/shackle mounts looked OK.... correct?
The reason I say this is because by measuring to the body you are assuming the body is level on the frame. Bushings/mounts can be bad. Mounting points damaged/bent, etc. If nothing else, measuring frame to floor will give you the difference and confirm if body is on correctly.
Old 01-13-2018, 01:56 PM
Quote:
i didnt even look at the body mounts. i been staring at this frame for a bit. cleaned it off and looked for stress marks or something that would tell me theres damage. i got nothing
rad support looks good
Old 01-13-2018, 02:02 PM
i did measure from the frame to floor too. passenger side is a little lower. but it corresponds with how the passenger front is a little lower.
im still not sure from what. frame looks fine, mounts for the springs looked fine.
im gonna take a look at the spring mounts again.
arms would bend before the frame right? i do have the other excursion here still. i think i'll just swap out the suspension and see if it helps. at this point im at a loss anyway.
Front hub won't turn slour 1973 - 1979 F-100 & Larger F-Series Trucks 2 07-30-2017 03:42 PM
03 v10 blows out defrost only andy9743 Excursion - King of SUVs 3 02-16-2017 09:36 PM
1977 Highboy spring sag. What is factory height? tlrtucker 1973 - 1979 F-100 & Larger F-Series Trucks 6 10-26-2016 04:02 PM
1967 Highboy Lift Springs Super Duty Confused MongooseV8 1967 - 1972 F-100 & Larger F-Series Trucks 1 05-09-2016 12:26 PM
front spring swap gneill794 Excursion - King of SUVs 3 04-06-2016 12:22 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
