Sponsored by: Kumho
lowering advice.
Old Sep 13, 2003 | 09:53 PM
starweb's Avatar
starweb
Talking lowering advice.
ok I need to know the best way to lower my truck. is it a good idea to put the rear axle on top of the springs. how do i deal with the twin I-beam front suspension?
I have a '79 F-150 explorer. 460/4v
Old Sep 14, 2003 | 07:26 AM
76supercab2's Avatar
76supercab2
lowering advice.
The best way to lower the TIB suspension is by using either dropped I beams (The beam is longer and causes the spindle bot be higher) or dropped spindles (the shaft the wheel spins on is higher). Just cutting coils off the springs causes alignment difficulties for which there is no easy adjustment.
There used to be manufacturers of dropped I beams but I don't know of any right now.
Old Sep 14, 2003 | 03:06 PM
Mil1ion's Avatar
Mil1ion
lowering advice.
Suspension Related.
Moved to Suspension forun
Old Sep 14, 2003 | 06:18 PM
starweb's Avatar
starweb
lowering advice.
ok, so what about the rear? is putting the axle on top of the leaf springs a good idea?
Old Oct 8, 2003 | 01:04 PM
94I-6's Avatar
94I-6
Yes its called a flip kit but if you go to low you willl need to install a C-notch
Old Oct 9, 2003 | 11:47 PM
starweb's Avatar
starweb
ok, so explain what a C notch kit is and what does it do?
I will probably go only as low as just putting the axle on top of the springs. no blocks.
Old Oct 11, 2003 | 01:36 AM
94I-6's Avatar
94I-6
OH, no, no, no, We must never use blocks for lowering, bad idea.
Blocks make our U bolts to close to the ground, and they get bent some how or another. A C notch kit is a small cutout in the frame in th shape of a C.
frame
_____
--------/ axle ]-----------------
Best I can do drawing an image.
Gives you more axle travel when your lower.
Two thick metal plates are added to the front and rear of the frame cutout to reinforce it, and some kits even give you a new axle stop to put on the frame.
Old Oct 11, 2003 | 01:37 AM
94I-6's Avatar
94I-6
nevermind the picture didnt come out.Anyway
Old Oct 12, 2003 | 10:08 PM
Randyb12's Avatar
Randyb12
DJM has 3" drop beams for the front.
http://www.djmsuspension.com/Product...5F100Parts.htm
Old Oct 13, 2003 | 11:09 AM
starweb's Avatar
starweb
ok, cool. But, if I only use a flip kit on the back, wouldn't a 3" drop in the front be too much?
Old Oct 13, 2003 | 03:01 PM
Randyb12's Avatar
Randyb12
check out the lowering kit for the rear. I think it would be easier than a flip kit. With the lowering hanger and shackle from DJM you will get 4: drop which is what you want. from what I have seen so far you want the rear dropped 1" more than the front. I think the flip kit will drop you more than 4", more like 6".
Old Oct 13, 2003 | 11:42 PM
starweb's Avatar
starweb
ok, I looked at their website and they have no e-mail contact. I guess I will have to call them direct. I noticed that in all their pics they have none of 73-79 F-series p/u's I reaaly would like to see this done before taking the chance.
hunter62
Nov 25, 2009 10:29 PM
tonydlt
Mar 15, 2007 07:45 PM
sancochojoe
Apr 16, 2004 03:01 PM
Opiewan
Electrical Systems/Wiring
Sep 9, 2003 02:09 PM
Gene
Sep 18, 1999 09:28 AM
