Odd glow plug issue.
Old Jan 11, 2018 | 01:16 PM
540milotalon's Avatar
540milotalon
Standing in front of truck with test light light.
Old Jan 11, 2018 | 01:34 PM
Red97350's Avatar
Red97350
I'm tempted to say that you have an issue with your GPR. I would only recommend a Stancor or Western plow relay for your GPR. These trucks use a lot of power for the glow plugs. When was the last time you checked the wiring harness for the glow plugs? Have you used a meter on your GPR when the key is on to see what is going on with it?
Red
Old Jan 11, 2018 | 01:35 PM
Red97350's Avatar
Red97350
For the GPR, I would recommend using a meter so you can see how much voltage drop you have across the terminals. A test light is only going to show you that you have enough power to light a little light bulb.
Red
Old Jan 12, 2018 | 10:33 AM
knottyrope's Avatar
knottyrope
if you tighten the GPR posts too tight, you will twist the contacts and it might not work well after.
Same happens on fender starter solenoid on fords. they are copper and don't hold up well to strong torque
Old Jan 12, 2018 | 02:06 PM
Hussler's Avatar
Hussler
On the GPR one little terminal with key ON will show battery voltage all the time. The other little terminal is pulled to ground by the PCM to activate the GPR. Since it's intermittent I would check the connections on those two small terminals.
Some Other Troubleshooting:
Disconnect both small wires. Measure each with key ON. The one that has battery voltage comes from the ignition switch. Connect that wire back up to the GPR. Use a jumper wire on the other GPR small terminal and ground it to battery negative. Each time you do this the relay should energize. Removing the ground and the GPR will De-energize. You can do this as may times as you like with key ON to prove to yourself the GPR is operational.
It almost sounds like one of the small terminal wires at the connector to the GPR is bad - intermittent. Close inspection should revel that. A picture would help.
Old Jan 15, 2018 | 10:29 PM
540milotalon
Sorry I was so long getting back. On Saturday morn, while laptop was charging up the truck had been started 3-4 hours earlier and ran 15 minutes. When cycling key on/off the DVM read less than one (1) volt on load side terminal of GPR. Air temp 22*.
This morning, similar temps, truck was plugged up maybe 2 hours. A/E read oil temp 64* and coolant temp read 145* ???? After running about 15 minutes the dash gauge was below normal operating temp but the A/E live feed was reading 302* and outlined in red.
I picked up a new coolant temp sending unit and GPR and will try to replace tomorrow.
Old Jan 15, 2018 | 11:41 PM
madpogue's Avatar
madpogue
There is no PCM coolant temp sensor. The sending unit you bought was for the gauge. The only gauge that runs off the PCM is the tachometer.
Old Jan 16, 2018 | 08:02 AM
DIYMechanic's Avatar
DIYMechanic
^^ 2X.
The PCM only reads EOT, the only coolant temp sensor on the motor runs the gauge.
Old Jan 16, 2018 | 05:23 PM
540milotalon
You (me at least) would expect a new, out of the box GPR to last more than a few starts. New GPR, 12.6 on line side, 12.2 on load side. Truck started like a youngster again.
I would like to thank each of you for putting up with someone whose meds were off (and their GPR) but now fixed.
Check the simple stuff first.
Old Jan 16, 2018 | 05:41 PM
97-psd's Avatar
97-psd
Sadly, New does not equal good for GPRs.
I would recommend:
Monster White-Rodgers Glow Plug Relay
It will handle the high amp draw with no problem.
Old Jan 16, 2018 | 05:43 PM
Red97350's Avatar
Red97350
Glad you got it fixed!
Red
hhowell1990
Apr 10, 2011 07:34 PM
Jbrown8988
Oct 11, 2009 06:19 PM
gtlegacy
Jan 8, 2007 08:55 PM
Pickupmanx2
Dec 28, 2006 06:20 PM
rocknmud
Apr 18, 2006 12:25 AM
