How to know
Old Dec 27, 2006 | 06:39 PM
Pickupmanx2's Avatar
Pickupmanx2
Veteran: Marine Corps
How to know
I am going to work on a 95 F-350 PSD with 311k on her, the glow plugs (system) does not work, if not plugged in has a REALLY hard time starting... where do I start to figure out what isn't doing its job? What is common, GPR, timer, or glow plugs going out. Wait to start light comes on,,,, if that means anything.
Old Dec 27, 2006 | 07:26 PM
travisd's Avatar
travisd
I would lean towards the GPR. With the hood up, drivers door open, radio and fan off, you should hear it click when you turn the key on. The GPR click indicates that it is allowing 12 volts to the glow plugs. You should be able to take measurements to show that it is outputting 12 volts for sure. The glow plugs themselves are checked easiest by measuring their resistance.
Mine has one bad gp, but will still start at 10F, without much trouble, confirmed the other day. I do like to leave the key on for awhile after the "wait to start" light goes out.
Old Dec 27, 2006 | 07:40 PM
tjbeggs's Avatar
tjbeggs
yep what travis said. use a test light to check glow plug relay. it should have power on both large terminals when the truck is cold and the key is first turned on. If that tests good then use an ohm meter to test the glowplugs from the valve cover plugs(5 pins on each connector, 2 connector per valve cover, the outside terminals on each side are the glow plug terminal) Hook ground side of ohm meter to battery ground and touch positive lead to connector pins. should be 3 ohms or less. 1 ohm is ideal
Old Dec 27, 2006 | 11:23 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
With 311,000 miles I wouldn't bother testing anything. Replace the relay and the plugs and be done with it.
The WTS light working means the PCM is sending it's signal, so in effect the "timer" is good.
Old Dec 28, 2006 | 05:40 PM
Pickupmanx2
Ok, Thanks guys, but,,, how hard are the plugs themselves to replace?! approx. cost of plugs, haven't priced them yet.
Old Dec 28, 2006 | 05:48 PM
Stroker 94 1/2's Avatar
Stroker 94 1/2
Easy job to do. Just take off the valve covers and there they are. Plugs are around $8-$10 each.
Old Dec 28, 2006 | 05:50 PM
ltfox's Avatar
ltfox
Plugs are +/- 10 bucks each. Make sure you get motorcraft beru plugs. Do not get autolites. Changing them is'nt too bad. Hardest part is pulling the valve covers.
Old Dec 28, 2006 | 05:52 PM
ltfox's Avatar
ltfox
Man Stroker your too quick for me......LOL
Old Dec 28, 2006 | 06:06 PM
travisd's Avatar
travisd
Somebody has to play devil's advocate, but it's entirely possible that some of those parts may have been changed not too long ago. Plus, the benefit of troubleshooting and identifying the broken part is a bonus, for those who have not done it before.
Old Dec 28, 2006 | 06:20 PM
bkcowboss's Avatar
bkcowboss
I am with cookie, the peace of mind of having brand new stuff is worth the 120 bucks. Also IMO if you don't know when your GP's were changed last you need to change them now!! There are way to many guys that are breaking those things off, all it takes is one to have to much carbon and you are in for a lot of work and expense.
Stroker 94 1/2
LOL, Sorry ltfox, it happens to me to!!
67camaro
15
Jul 9, 2016 11:12 AM
troverman
6.7L Power Stroke Diesel
28
Nov 23, 2015 07:11 AM
F350XLT
Mar 13, 2015 05:12 PM
ScottInTexas
Jul 10, 2009 06:57 AM
ronsonmax
Feb 29, 2008 07:41 PM
