Sponsored by: Innova
power delay?
Old Apr 12, 2006 | 07:45 PM
rocknmud's Avatar
rocknmud
power delay?
Installing a new head unit Kenwood DDX-6019 in 2005 f-350. Is there a power source that starts after the wait for the glow plugs? I hate that the radio starts and then goes off when I start the truck. Or how about a power source that does not turn the radio off when starting? That would be better. Thanks for any help.
Old Apr 12, 2006 | 09:44 PM
fordboy_52's Avatar
fordboy_52
im not sure if there is a way without a switch
Matt
Old Apr 13, 2006 | 12:12 AM
furball69's Avatar
furball69
http://www.davidnavone.com/detail.asp?PRODUCT_ID=N-66A
30 seconds long enough for the glow plugs? Only thing is, once it is started, there will be the 30 second wait again for the radio to come on.
Old Apr 13, 2006 | 02:39 AM
IPACA9's Avatar
IPACA9
that's strange... I posted a answer to this earlier and now it's gone... unless it just didn't post.
The Red with Green stripe on behind your fuse block or at your ignition harness is a true ignition that does not drop out during crank. You can hook your radio there.
Old Apr 13, 2006 | 07:39 AM
fordboy_52's Avatar
fordboy_52
the server is having problems from time to time kc. sometimes the stuff u post gets deleted. im having the same problem
Matt
Old Apr 17, 2006 | 07:56 PM
rocknmud's Avatar
rocknmud
The Red with Green stripe on behind your fuse block or at your ignition harness is a true ignition that does not drop out during crank. You can hook your radio there.[/QUOTE]
Yes that does work but no power with the key in acc. Do you know of another source?
Old Apr 17, 2006 | 10:00 PM
IPACA9's Avatar
IPACA9
The wires that work with the key turned back is going to give you that delay. So that they don't rob power that's needed for cranking.
Old Apr 18, 2006 | 12:25 AM
paul100's Avatar
paul100
I have a Pioneer AVIC-D1 and I have worried about this as well. Do you think it's hard/bad on the HU?
oscardavila
1997 - 2003 F150
Jul 18, 2010 06:14 PM
hdbluedeuce
Mar 20, 2009 05:50 AM
eric777
Apr 4, 2007 12:09 PM
qdude79
1997 - 2003 F150
Apr 12, 2006 08:09 AM
