Sponsored by: Real Truck
Headlights
Old Jan 5, 2018 | 09:19 PM
Vinford's Avatar
Vinford
Headlights
2002 F-350 Crew Cab 4x4 5.4 engine
Headlight problem.
Low beam and dash lights don't work?
Old Jan 5, 2018 | 09:26 PM
73F700's Avatar
73F700
low beam and dash are both controlled by one switch on the dash - check for power at the switch. Have you confirmed fuses are all good?
are your clearance/marker lights working?
Old Jan 6, 2018 | 10:18 AM
Vinford's Avatar
Vinford
I checked fuses but theres lots of relay looking boxes in fuse panel?
I don't have a manual for truck so don't know which one runs what?
Old Jan 6, 2018 | 01:22 PM
alloro's Avatar
alloro
Here is a PDF of your owners manual. Fuses start on page 162.
File Type: pdf
Old Jan 7, 2018 | 11:50 AM
Vinford's Avatar
Vinford
Seems to be more to this than first thought.
I just noticed my taillights come on with the key , you don't need to turn switch on.
They work proper , signals etc but go off and on with the key?
Old Jan 7, 2018 | 02:48 PM
73F700's Avatar
73F700
do you mean if you press the unlock button they come on for a minute or so? isn't that normal?
or are you saying that when you turn the key to 'on' position you have running lights even though the light switch is turned off?
Old Jan 7, 2018 | 08:19 PM
Vinford's Avatar
Vinford
I have taillights when my key is turned on but light switch is off.
crazzyt9
Sep 14, 2016 04:31 PM
79 f-150 guy
Electrical Systems/Wiring
Aug 11, 2009 05:51 PM
Vinford
Aug 16, 2006 04:06 PM
theokcowboy
Oct 31, 2005 07:39 PM
cbeaur
Nov 13, 2003 04:31 PM
