dash lights
Old Nov 13, 2003 | 11:11 AM
cbeaur's Avatar
cbeaur
dash lights
I can not seem to locate the problem with my dash lights not working. The bulbs are fine the wiring seems to be fine as well, is there somewhere else I should be checking before I lose my mind?
EDIT:
Truck is an 89 F350
SORRY
Old Nov 13, 2003 | 11:43 AM
GeneStoner's Avatar
GeneStoner
FUSE?
Old Nov 13, 2003 | 12:11 PM
cbeaur's Avatar
cbeaur
It's not the fuse already checked that
Old Nov 13, 2003 | 01:40 PM
Mil1ion's Avatar
Mil1ion
Have you turned the headlight switch **** to maximum ?
Old Nov 13, 2003 | 03:11 PM
drunkenmonk's Avatar
drunkenmonk
dash ground?
Old Nov 13, 2003 | 03:15 PM
cbeaur's Avatar
cbeaur
Dash ground? Help me out here, I know what grounding is but not sure what you mean here
Old Nov 13, 2003 | 03:19 PM
drunkenmonk
I've had the most confusing problems caused by a loose strap from the dash to ground
this wasn't on a ford, but I'd still make sure all ground connections were good first
Old Nov 13, 2003 | 04:31 PM
Franklin2's Avatar
Franklin2
Also this part of the headlamp switch could be burnt out.
