Sponsored by: Real Truck
02 Superduty headlights
Old Aug 13, 2006 | 11:52 PM
Vinford's Avatar
Vinford
I have a 02 SD F-350 crew cab and the high beam seems to not be working?
Anyone else had this problem?
Everything else seems to work fine.
Old Aug 14, 2006 | 11:15 AM
Vinford's Avatar
Vinford
Anyone got any ideas?
Old Aug 15, 2006 | 12:03 AM
RACERX7775's Avatar
RACERX7775
check the fuse, relay, check if the indicator light on the dash comes on, check with a test light at the headlight plug to see if you are getting a signal.
Old Aug 15, 2006 | 12:38 AM
Vinford's Avatar
Vinford
the dash indicator does not come on.
Fuses are good.
Relay? Is there a relay in the fuse panel?
Also the super brights or passing lights or whatever you call them dont work either.
Low beam , dash lights etc all work normal.
Old Aug 15, 2006 | 01:10 AM
ryaneverk2's Avatar
ryaneverk2
Since the dash indicator does not come on, it seems that you're not getting a signal from the multifunction switch (the lever for the blinkers, wipers, and hi-beams).
Double check fuse #16 under the dash, 15A fuse, just in case. It's for the high-beams. However... since no indicator on the dash, makes me still think that truck isn't seeing the signal from the multifunction switch to activate hi-beams.
Old Aug 15, 2006 | 10:26 AM
Vinford's Avatar
Vinford
And the multifunction switch is the main switch in the steering column?
So trip to Ford I guess?
Thanks for the input.
Old Aug 16, 2006 | 03:51 PM
ryaneverk2's Avatar
ryaneverk2
It is the big lever that controls your headlights, blinkers, and high beams, coming out the left side of the steering column. I think I recall it being a $120 part or so, but I can't remember for sure. You can replace it yourself if it's the problem. But a Ford dealership could take care of it as well.
Old Aug 16, 2006 | 04:06 PM
fireman28's Avatar
fireman28
Check your local parts house. You can likely get one from them cheaper. Some of them can order it in Motocraft if they have a distributor that carries them.
plumbkrazy428
Feb 27, 2012 08:51 PM
tnardo
Oct 6, 2009 05:06 PM
02sd
Crossovers
Sep 23, 2009 11:23 PM
kwajite02
Sep 28, 2008 11:37 AM
officer131
Feb 7, 2008 09:52 AM
