dash lights dont work..HELP
Old Feb 22, 2009 | 06:33 PM
79 f-150 guy's Avatar
79 f-150 guy
my dash lights on my 79 stoped working and i cant figure out why, i checked my fuses, cleaned up all connections on the back, and as a last ditch effort replaced all the bulbs....... is there a hiddin relay or somthing that i'm missing. i was told thats a commen problem with 70's ford truck but nobody i know knows how to fix it..........a little help would be great. thanks
Old Feb 22, 2009 | 08:06 PM
Franklin2's Avatar
Franklin2
A common problem with them would be the dimmer control on the headlight switch. Make sure you have power coming out of the switch on the blue/red wire. Also you can pull the fuse for the instrument lights and make sure you have power on one of the fuse terminals with the headlight switch pulled out.
Old Aug 11, 2009 | 08:54 AM
Wincharter's Avatar
Wincharter
Dash light problem
I have the same thing going on. Checked all my fuses, OK. Also lost on head light warning for when you turn truck off and pull key. The dimmer switch you speak of dims the dash lights, also turns on overhead lights?
Thanks,
Bill
Old Aug 11, 2009 | 10:15 AM
Volvo92906's Avatar
Volvo92906
Yes, it controls dash lights, cabin lights, marker lights, and headlights. Headlight switches do go bad.
Old Aug 11, 2009 | 05:27 PM
Wincharter's Avatar
Wincharter
Thumbs up Dash lights
Volvo 9,
I do appricate your reply. Can't believe that thing only lasted 7 yrs, lol. I have 186,000 on ole Grey and like you said stuff gos bad after a while.
Thanks,
Capt'n
Old Aug 11, 2009 | 05:51 PM
Franklin2's Avatar
Franklin2
Get a meter or testlight, and with the headlight switch pulled out, check for voltage on the instrument light fuse.
marty277
Mar 18, 2013 03:11 PM
79OldBone
Oct 4, 2011 12:24 PM
Clifford79F250
Nov 14, 2010 07:19 PM
70_f100
Electrical Systems/Wiring
Mar 6, 2006 12:01 PM
headmark
May 16, 2004 04:10 AM
