Injector codes - resolved
Old Jan 24, 2018 | 11:51 PM
Yahiko's Avatar
Yahiko
Originally Posted by navistarnut
Forscan will do the buzz test, I think it's called the injector test.
Works great......I've always found for some reason after I test something using that test it fires up with greater authority, more so than normal.
I'm guessing it's because the fuel pump has been cycled and each injector has been active.
But without any high pressure oil you don't get anything.
Also are you starting this up right cold right after? I would
think glow plugs might give some affect.
Old Jan 25, 2018 | 09:36 AM
flysniper's Avatar
flysniper
I didn't know that....
I'm going to have to look into that. I haven't touched FORScan. I guess I need to dig into it. I thought I read somewhere that it didn't have that capability (cause the internet is never wrong). I'll see if I can find some time tonight to look at it.
I thought the buzz test was a signal test only. There injectors were NOT physically actuated?
Thanks for the heads up.
mike
Old Jan 25, 2018 | 04:11 PM
Yahiko's Avatar
Yahiko
The coils are energized and the spool valves move.
But without high pressure oil no fuel moved.
cookingguy
Dec 6, 2015 12:20 PM
cabloom300
Jan 24, 2014 06:39 PM
Teds
Feb 15, 2012 07:42 PM
2006powerstroke90
Oct 13, 2011 08:44 AM
jmaskew
Aug 21, 2011 05:47 AM
