Missing?? Injectors?? Codes?? Help
see posts from #23-#30 on new issue
i was just getting ready to post updates..
sgII not in yet...
i am know getting constant miss even after warmed up, so i took it to mechanic last night to have him check ficm, he went to drive it and said wow this things missing bad, w truck warm, it was as 48.5 dropped to 47.5 cranking.he ran codes came up w P0237, P0272, P0403,P0480, P0528....
did injector diag, #4 was changing as low as -48 while the others remained at 0
he had me leave it so he could check it this am when cold. went over this am he hooked it up, ficm - lowest it was was47.5 cranking and stayed at abt 48.. so looks like ficm may b okay..
injector diag showed #4 #6 #7 all dropping to negative numbers jumping all over the place, he suggested we use the bg clean system, one qt treats fuel, 2nd treatment goes directly in the oil, stuff was like alcohol, let set idle for 1.5 hrs, drained and purged system, new oil filter and royal purple 15w40 and 1 qt of bg DOC, diesel oil conditioner......went and drove truck was still missing a little..
he had reset the codes earlier but the codes came back showing #4 injector, told me to drive it for awhile to work in the fuel treatment, upon driving it will clear up and run great then start the miss agn under acceleration, then clear up agn....
thats where i am to this point...this was from friday...
last night after leaving work have the same problem, missing very bad cutting out until it warmed up, then still has a miss....
same thing this am
also noticing that upon start up it is giving me blue smoke while it is sitting and idling.....
any help would be greatly appreciated, we are stumpped (unless it is the injectors)
what is the correct fuel pressure??
i will have to get to him cause i dont even know what to look for, if the plug was not all the way in would it clear up after wareming up?? i called him abt ground, he said he knows its good had to put new ground ring on that wire...
yesterday morn it didnt really want to start, waited for light to go off, crank it then it would try to fire off and die, did that 3 times before she cranked up....
my tech is saying he feels it needs 3 injectors, as i have told him thats fine i just want to make sure that is problem before proceeding, he says that all the vitals are good so leads him to beleive thats our problem, i just want everything else ruled out...
heres the next thing, if it is injectors, injectors are 225 each x 3 +tax + install abt 1200 bucks......he has 125hp inj in his truck, they have 1000 miles on them, he is upgrading to 285cc/305hp inj, he will make me a deal on all 8 inj that wont be much more than just replacing the 3 stock inj....would this be a wise decision??? remembering that i have new heads, gaskets, injector cups etc.....
and he has an extra ficm there, r they all compatible?? if so i will see if we can switch it out to rule it out
