T-case shift lever bushing
Old Jan 6, 2018 | 05:00 PM
wharthog's Avatar
wharthog
I was under the belief that the later obs shifter that gets pushed down to pass neutral had a smaller bushing than the shifter that gets rocked outboard to pass neutral. Thanks to the listing below we can see they share the bushing because it calls out under 1987/96 F150/350 & Bronco. Good to know.
E3TZ-7335-A = 1983/89 Ranger; 1984/89 Bronco II; 1987/96 F150/350 & Bronco; 1997 F250 H/D & F350 / Obsolete ~ Available NOS
So, It appears both of the different transfer case shifters share the same bushings on the pivot bolt. I thought they looked too different in the pics I have seen. Thats what I get for looking at pictures and not reading, lol.
Thanks to NumberDummy again for his help on this site.
Old Jan 6, 2018 | 05:24 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
See edited post #14 for sources/phone numbers for EOTZ-7335-C & E3TZ-7335-A bushings.
Old Jan 6, 2018 | 05:40 PM
NumberDummy
Upper pic: EOTZ-7335-C
Lower Pic: E3TZ-7335-A (I assume)
Old Jan 7, 2018 | 06:25 AM
wharthog's Avatar
wharthog
Are those pics general in nature or should my shift lever match one or the other? I ask because it doesn't match.
Old Jan 7, 2018 | 12:39 PM
NumberDummy
This is the only other pic, but it doesn't show any bushings.
Old Jan 7, 2018 | 01:01 PM
Azryael's Avatar
Azryael
My setup matches this last one, since the ZF and 1356 in my truck are out of an '89, and the pivot bolt uses that very bushing that is being looked for.
Only reason I haven't permanently installed my own shifter is that I don't have the boot, since the boot in the donor truck was all torn up.
Old Jan 7, 2018 | 04:47 PM
wharthog's Avatar
wharthog
Azryael, is your pivot bolt huge, like with a 1.125" hex head bolt?
Old Jan 7, 2018 | 05:01 PM
Azryael's Avatar
Azryael
Something like that, yeah. I've not measured. I backed it out a ways after testing the T-case to made sure it worked after my swap because I was going to clean it all up.
Let me go snap a photo real fast.
Old Jan 7, 2018 | 05:08 PM
Azryael's Avatar
Azryael
Here you go:
If you look at the head of the big bolt, you'll see the rim of the bushing in question.
I may just be careful and apply some white lithium grease to it and take it from there.
Old Jan 7, 2018 | 05:52 PM
wharthog's Avatar
wharthog
Yes, that looks like my set up, only its the southern version, (no REAL rust). What size hex is that pivot bolt?
Old Jan 7, 2018 | 07:01 PM
Azryael's Avatar
Azryael
Well, just a quick measure with my calipers without yanking the bolt comes up to just over 1 5/32", or just a bit over 29.3MM, so a 30MM should fit it just enough without risking rounding it off.
Old Jan 7, 2018 | 09:08 PM
wharthog's Avatar
wharthog
Great, now to find the proper bushing.
pirschwagon
Nov 22, 2017 08:59 AM
money pit 69
Jun 26, 2010 09:59 PM
00f250sd
Oct 26, 2009 07:06 PM
girlwithatruck
56
Oct 11, 2009 12:31 AM
Mulletwagon
1978 - 1996 Big Bronco
Aug 18, 2001 09:21 PM
