Transfer case problem
Old Jun 26, 2010 | 08:38 PM
money pit 69's Avatar
money pit 69
My friend has a 1987 F-250 V8 automatic, that will not let us shift the transfer case. It was working then we went to tow a truck out of the blackberries locked the hubs in tried shifting and then the trouble started. We have checked the linkage and it looks fine. We have tried it in neutral, park, running, not running, from time to time we have been able to get it back into 4 low. When you shift the gear shift into park and the truck is running it grinds like crazy. Any ideas we would appreciate. THX David
Old Jun 26, 2010 | 09:59 PM
danr1's Avatar
danr1
Sounds like you just have shifter issues. Give it a proper lube and that should correct the problem.
Linkage is no more the a single steel plate with a nylon bushing at each end requiring little to no lube.
The shifter itself however is much more involved, it pivots on a large bolt, they tend to seize up at that point when not used regularly.
Then sometimes what feels like it's moving correctly again is that bolt pivoting via the threaded end where it screws into the bracket, rather then the bolts shank where its supposed to.
Shifting to N or 4L requires the lever to move straight down first then back, a little roll pin clears the notch in the plate at the bottom of the shifter. Its not internal to the shifter so you can see it.
Gotta get a can of penetrate/lube of choice and spray the heck out of it carefully working it free again. Watch the head of the pivot bolt, make sure its not turning with the shifter.
The shaft where it moves up and down for 4L, its bushings are covered by rubber boots top and bottom, small zip ties maintain a water tight seal. Clip the zip tie at the top and spray inside it to free up that point, might have to work from the bottom too, be sure and replace the zip ties once its working freely again.
TCs not in a gear so the trans is spinning with the motor, the park pin you hear grinding.
Oh wait you said 87, that ones different, you move the lever back to 4H and then left and back to get to N and 4L IIRC? Anyway look it over a minute you'll see what and where that part needs a lube job.
