Broke down ... advice please
Old Jan 2, 2018 | 06:27 AM
dieselsubmariner's Avatar
dieselsubmariner
I have not opened it, so no idea, if it had water.
however I drove to work this morning and still had a lot of skip.
hope I make it home tonite, so I can throw the computer back on.. wonder whats going on though..
Old Jan 2, 2018 | 08:41 AM
B-Rad88's Avatar
B-Rad88
Veteran: Navy
Do you have a chip? If you don't know, pull the e brake bracket off and behind that is the back of the PCM where a chip would go if you had one.
Mine would act like it was missing and sometimes it would lose all power for a second or 2, then be fine, happened while driving. Turned out to be a POS chip a previous owner had on there and it was loose. WTS light would come on usually when this was happening.
Could be a PCM issue. Hard to tell when you're not in person.
Old Jan 2, 2018 | 09:07 AM
dieselsubmariner
The truck has no chip. its bone stock :-)
so I might have to check the harnesses to the injectors as well as test the IDM again.. maybe my old idm is bad as well.. the truck I pulled it from, had several sensors and several injectors bad.
Old Jan 2, 2018 | 09:14 AM
oldbird1965's Avatar
oldbird1965
From my experience an IDM either works or it doesn't work. A bad IDM stranded me a couple of years ago and it showed a cps code.
Old Jan 2, 2018 | 09:59 AM
Bearhugger1933's Avatar
Bearhugger1933
Had a problem with mine ,sometime it would start and run fine and sometimes it would not start,found that the computer was acting up, sent it off and got it repaired for 89.00 dollars no more problem.
Old Jan 2, 2018 | 10:32 AM
dieselsubmariner
I guess if the computer is messing up, im not necessarily getting a code? I do have a spare automatic pcm though . I did notice this morning that the idle is ok, even though it sounds like a very minimal surge.. the most skip came in over 1500rpm I think..
Old Jan 2, 2018 | 02:35 PM
Bearhugger1933
Nine didn't show a code either.
Old Jan 2, 2018 | 03:34 PM
dieselsubmariner
Ok... made it home, quiet a bit of skip.
Buzz test was good, no codes.
when doing running test , I got a p0476 exhaust pressure control valve range code. Truck still skips, no further code..
mhh
Old Jan 2, 2018 | 04:47 PM
madpogue's Avatar
madpogue
Until you get this resolved, you should carry the AE laptop with you wherever you take the truck. I would even consider having it running in the center seat while underway, just to see if AE catches anything when you get the skips/hesitation.
Old Jan 2, 2018 | 05:21 PM
dieselsubmariner
The skip is to bad for me, so I’m not driving the truck until it’s fixed. I still think the idm I had is bad as well
Old Jan 2, 2018 | 06:21 PM
B-Rad88's Avatar
B-Rad88
Veteran: Navy
I have read lot's of stuff online where an IDM would fail, and one bank would go out, or it wouldn't even let you start the truck. But I have read a few people say they have had one or 2 banks fail because of the IDM. I think the UVCH can burn up and can mess up the IDM.
The PCM acting up doesn't always throw codes. The PCM is what throws codes so if it's having issues it might not always throw a code for something. When the crappy chip that I had on my PCM was dislodging, it would trip the WTS and it would lose all power temporarily. Once it wouldn't start and it threw no codes during that time.
Old Jan 2, 2018 | 08:00 PM
oldbird1965
Usually when a problem develops with the UVCH the IDM will shut down that side of the motor to protect itself. Shake the IDM to see if you hear water inside.
Alduncan19
May 15, 2016 06:38 PM
300inline6
20
Jun 26, 2012 05:09 AM
killforfood
18
Jul 3, 2009 11:19 AM
Craig64
19
Feb 28, 2004 09:43 AM
mybigredford
Feb 1, 2004 02:23 PM
