7.3 intiation
Old Dec 31, 2017 | 05:01 PM
MustangGT221's Avatar
MustangGT221
7.3 intiation
So long story short I was a big gasser guy lost my old truck on to a new project. a 96' f250 CCSB Centurion 7.3L. Just picked it up in June 2017. Truck has PO mods - intake/exhaust, TS6, Rosewood 160/stock injectors, stock turbo, Adrenaline HPOP, Efuel. Has ATS trans w 100k mi that just blew front pump seal despite shifting/working fine. Trying to finalize a solid combo.
Thinking since the trans blew the seal, it's time to sell it off and get a stage II Sam Wyse trans. Then upgrade to new exhaust manifolds while the trans is out.
Not sure what to do with up-pipes/turbo/spyder/intake tubing and injectors.
What would you suggest? Looking for 4-500hp reliable and able to handle all conditions including cold weather.
What else should I do while the trans is out?
Old Dec 31, 2017 | 06:53 PM
fordpride's Avatar
fordpride
180/80 injectors
Pushrods
Valve springs
Irate t4 kit with s465
Intercooler
Custom tuning
Old Dec 31, 2017 | 07:40 PM
85F250Diesel's Avatar
85F250Diesel
Who is Sam Wise? Never heard of him.
Old Jan 2, 2018 | 07:06 PM
B-Rad88's Avatar
B-Rad88
Veteran: Navy
Stage 1 or 2 injectors, D66 turbo if you keep stock housing, intercooler, HPOP (adrenaline or terminator), 6637 air filter and the other one I see recommended is the S&B intake which I have but don't like, e fuel, and then custom tunes. Should only cost you about the same as a small mortgage.
Old Jan 2, 2018 | 08:06 PM
97-psd's Avatar
97-psd
If you start down this path, don’t waste your money with different turbo housings just spend the coin and get a t4 setup. Big fuel needs big air, you will constantly be fighting EGTs if you don’t.
Mike has pretty much everything you need listed
Old Jan 3, 2018 | 09:09 AM
knottyrope's Avatar
knottyrope
"handle all conditions including cold weather"
upgrading to stancor GPR and make sure your GPs are good by ohming them out and use only ford ones
check block heater
check armature clearance on injectors ( too little retards timing and makes for hard starting )
before spending lots of money, maybe a compression test is a good idea
Fuzzynuts
13
Sep 17, 2017 08:55 PM
ToddMyers58
18
Jan 27, 2017 08:43 AM
199673Nick
15
May 26, 2015 10:58 PM
93f250tn
Dec 11, 2014 11:13 PM
USAF CCM
May 18, 2008 09:34 PM
