Broke down ... advice please
Old Jan 1, 2018 | 12:27 PM
dieselsubmariner's Avatar
dieselsubmariner
Well, broke down on the side of the interstate . I’m getting a tow in a bit, but need some advice : truck all the sudden stopped runnng. She turns over , but no start. I have fuel in the filter housing, tach goes up to about 500 while trying to start.
i have a&e at home , but like to get some ideas in advance . Thanks and happy new year .
btw, 1996 F350, 200kmls, automatic .
o did had the impression in the past few weeks that every now and then I have a skip.. just one ..
Old Jan 1, 2018 | 12:56 PM
farmert's Avatar
farmert
Sound like a cam position sensor to me. If you replace it use a Motorcraft or IH only. parts house ones don't play nice with these engines.
Old Jan 1, 2018 | 01:05 PM
dieselsubmariner
I thought if the cam sensor goes out, your tach won’t move?
but I will check on it as I think I have one at home .. still waiting on tow right now though 😳
Old Jan 1, 2018 | 01:15 PM
Hussler's Avatar
Hussler
Skip, like dead silence is usually the CPS, very intermittent. If it's turning over at 500 RPM it must be trying to fire so it still could be the CPS. That would be my guess with information provided. Good luck, report back with actual fix please.
Old Jan 1, 2018 | 01:34 PM
fordpride's Avatar
fordpride
Do you hav a WTS light ?
Old Jan 1, 2018 | 04:19 PM
dieselsubmariner
​​​​​​​​​​​​​​WTS Light works, CPS sensor did not help .
right now my batteries are pretty low and I can also not connect with my A&e . All fuses below hood are good
Old Jan 1, 2018 | 05:20 PM
madpogue's Avatar
madpogue
Charge the batteries, try AE again, and do a buzz test.
Old Jan 1, 2018 | 06:10 PM
dieselsubmariner
Ok , here an update.. Truck is running 😊.
first off, the fuse under the dash for the cigarette lighter was blown... it also supplies power to the service port. Replaced it and hooked up a&e and connected.
The initial error code showed CPS , which I replaced. Since I had still no start , I did the KOEO test..
it showed both injector banks circuit high , cylinder 8 and 3 high and idm failure.
i still had another old idm, which I tried and she cranked right up.. KOER Test passed.
Hope I don’t brake down the next three days, but I guess I need to change the uvch harness or at least check...
thanks
Old Jan 1, 2018 | 06:16 PM
B-Rad88's Avatar
B-Rad88
Veteran: Navy
Same thing happened to me a few days before Christmas on the I-10 between Phoenix and Los Angeles. Had to pay over $300 for a tow to Buckeye and baby it back home. Mine isn't such an easy fix however. I'd maybe send that IDM in for a rebuild so you know you have a good spare. I'm going to buy a spare one sometime this year just to have.
Old Jan 1, 2018 | 06:24 PM
dieselsubmariner
If I send in the IDM .. any suggestion, who does not charge a lot ?
Old Jan 1, 2018 | 06:36 PM
B-Rad88's Avatar
B-Rad88
Veteran: Navy
I don't know for sure, but I think Swamps,is the only company that messes with IDM's. I think others rebuild them but Swamps I think is the only one doing modification to them like upgrading the voltage and the frequency. I was probably just going to buy a super duty IDM online.
Old Jan 1, 2018 | 08:16 PM
mcali2's Avatar
mcali2
What years super duty work? 99 to 03?
Old Jan 1, 2018 | 08:19 PM
B-Rad88's Avatar
B-Rad88
Veteran: Navy
Yes as long as it's a 7.3
Old Jan 1, 2018 | 08:39 PM
madpogue's Avatar
madpogue
If you can't get that IDM rebuilt, just get another one from a JY truck. Spare PCM+IDM are good to carry with.
Old Jan 1, 2018 | 11:28 PM
fordpride's Avatar
fordpride
Did it have water in it ?
