Minnesota Chapter Join Chapter, Leader: fordpower88
2018 is here BS thread!
Old Jan 30, 2018 | 01:00 PM
  #346
MisterCMK's Avatar
MisterCMK
Using the 47rh I assume?
Old Jan 30, 2018 | 02:10 PM
  #347
fordpower88's Avatar
fordpower88
Originally Posted by MisterCMK
Any reason you didn't keep the factory ecu and use that for trans control?
This is the diesel project, right? From what I remember working with the older Chrysler is that the ecu is almost standalone by itself
Yes the 47rh. Yes this is a diesel project otherwise I would not be doing this silly! This just seemed simpler to me. All set and done in smaller package then the ecu. I can set my own shift points make adjustments as needed. Almost like a tuner. Should be much easier to diagnose if I have problems then if I am using the ecu. Of the research I did this seemed pretty popular in this type of conversion.
Old Jan 30, 2018 | 08:35 PM
  #348
DieselCamper01's Avatar
DieselCamper01
Good evening guys. Finally starting to feel human again.
Old Jan 30, 2018 | 09:28 PM
  #349
fordpower88
Good evening Jay! That is always a plus.
Old Jan 30, 2018 | 09:37 PM
  #350
DieselCamper01
For sure. It wasn't terrible but I hate coughing, hacking, blowing my nose all day long.
Old Jan 30, 2018 | 09:41 PM
  #351
Tom's Avatar
Tom
Good evening, guys!
Glad to hear you're feeling better, Jay. Lots of sick going around up here, I'm the only one in my office who hasn't caught anything yet. Not sure if I'll make it through unscathed, I fear my time is coming.
Got my new over-the-range microwave installed tonight, it turned out to be a bit easier than I thought it would. Aside from needing help lifting it into place, it was a piece of cake.
Old Jan 31, 2018 | 05:27 AM
  #352
wildstang's Avatar
wildstang
VT Chapter Ldr
Good morning and have a productive hump day MN
Happy microwaving Tom
Old Jan 31, 2018 | 05:36 AM
  #353
Tom's Avatar
Tom
Good morning, guys!
Old Jan 31, 2018 | 07:13 AM
  #354
fordpower88
Good morning crew!
Old Jan 31, 2018 | 07:38 AM
  #355
DieselCamper01
Good morning Jim, Tom, Troy.
Old Jan 31, 2018 | 12:40 PM
  #356
fordpower88
Good afternoon guys!
Had a nice mess in part of my shop this morning. When into the second part of my shop where my tractor and boat sits during the winter and sometime since yesterday the valve stem blew out of the tractor tire. Not a big deal except location was towards the bottom and there is fluid in my tires for weight or correction there was. All the fluid leaked out which was a lot!! Its chloride to so not like it dries up like water. What a mess and no drain in that part of the shop either.
Old Jan 31, 2018 | 01:54 PM
  #357
DieselCamper01
That sucks Troy.
Old Jan 31, 2018 | 04:04 PM
  #358
fordpower88
Yep and chloride does not dry so used some floor dry for part of it and once I get the tractor tire fixed and out of the way I will have to try and squeegee the rest of it out. I figure there was about 40 gallons or so in there.
Old Jan 31, 2018 | 05:14 PM
  #359
HP junkie's Avatar
HP junkie
Evening fellas!
Well it was a productive day....sorta. Got a new carb kit installed in the ice auger. Started it and had gas running out of the exhaust! Took it apart again and realized I hadn't tightened the needle and seat very tight. Fixed that problem then went fishing. Nada, nothing only a couple bites. Came home and started chicken. Bummer.
But my day was better than yours Troy. That sucks!
Old Jan 31, 2018 | 06:37 PM
  #360
DieselCamper01
Ouch Troy.
Good job on the rebuild Cory.
