Socket won't engage spark plug...
Old Dec 31, 2017 | 02:23 PM
StarFox's Avatar
StarFox
New to me - 10k miles ago - 2008 5.4L, taking on the task of changing out my plugs and coils. I had a misfire code on #4 cylinder.
I noted that I had aftermarket coils in place so I figured the plugs had been changed at some time prior (135k miles ). Taking the great advice I've found here in the forum I proceeded to start on the passenger side of the engine.
The problem was evident immediately, the boot on #4 was covered in carbon. Plugs one and two came out easily, too easily like they were not torqued enough. Cylinder 4 didn't even break, it screwed right out like it was loose.
But my problem is with #3. Looks fine down in the hole, nothing in the way, but the socket won't engage the plug - just spinning as if the socket wouldn't go on far enough. I tried a deeper socket but that didn't help. Any ideas on what's going on? Could this be a broken plug that I keep hearing about?
Old Dec 31, 2017 | 06:04 PM
Ted928's Avatar
Ted928
Spark plug sockets have a rubber insert so it takes some force to get the socket down over the plug's head. Turning while pushing down should enable it to slide down and over the plug. If that doesn't happen, then I think you may have the wrong size socket.
Old Dec 31, 2017 | 08:14 PM
steve(ill)'s Avatar
steve(ill)
look at a couple of the plugs you have removed... Are the two pieces, crimped together near the hex ? ( factory original) Could the one still in the hole be spinning at the crimp, or is it really not engaging the socket ? What brand is the old plug ?
Old Jan 1, 2018 | 10:06 AM
P.Bronner's Avatar
P.Bronner
A couple years ago I actually got an oddball sp515 right out of the box. It was 15mm not 9/16. I can't begin to explain it, but it happened to me.
Old Jan 1, 2018 | 10:50 AM
StarFox's Avatar
StarFox
Ted928, yeah I've tried pushing down but it never seems to click in. I even tried the 5/8th inch spark plug socket but that didn't work either. I suppose it could be a different socket, I'll have to try some others.
Steve, I'm not out to my truck yet but I'll check. My thought was that maybe it was spinning at the crimp. I never got to apply force to the plug so if it is broken it has been operating that way. If it is indeed spinning what is the fix? Break it and use the Lisle tool?
P.Bronner - I find it difficult to believe that it might take another socket, but I'm going to check. No idea as to what the PO might have done. As easy as the other plugs were to come out I was expecting this one to do the same. I'll try some other sizes.
Old Jan 1, 2018 | 12:51 PM
P.Bronner's Avatar
P.Bronner
I found it nearly impossible to believe that a plug could have the wrong base on it but I held it in my hands. After what I've been reading lately about issues with the 515's, maybe not so hard to believe?... Good luck, I'm going to follow along.
Old Jan 1, 2018 | 01:52 PM
StarFox's Avatar
StarFox
Heading outside to work on the plugs in the 27 degree Carolina weather.
I grabbed the cyl. #1 plug, it is Motorcraft Platinum PZH-14F. There does not seem to be any crimp. So time to go see if I have a socket to fit....back soon.
Old Jan 1, 2018 | 03:03 PM
Ted928's Avatar
Ted928
If the plug is broken at the crimp, it will still thread out. The crimp is below the threads.
Old Jan 1, 2018 | 05:20 PM
StarFox's Avatar
StarFox
So, long story short, it looks like I have a small object, like a stone, wedged between the plug and sidewall - below the nut. That would explain my inability to seat the socket. Looks like I have a tedious job ahead. Any different ideas other than prying or hooking it?
Vacuum didn't get it nor did blowing it out.
Old Jan 1, 2018 | 06:40 PM
P.Bronner's Avatar
P.Bronner
If you can dislodge it with a hook, then it should blow out. Otherwise I'd probably try to crush it by driving the socket on, and then pull the socket and blow out the remnants.
Old Jan 1, 2018 | 09:14 PM
Tedster9's Avatar
Tedster9
At least you guys have degrees. We owe at least 18
Old Jan 1, 2018 | 09:43 PM
Ted928's Avatar
Ted928
Originally Posted by P.Bronner
If you can dislodge it with a hook, then it should bliw out. Otherwise I'd probably try to crush it by driving the socket on, and then pull the socket and blow out the remnants.
I have a box of wire used to prop up insulation bats. I have used it for so many things including hanging calipers. A stiff straight wire that can be easily bent serves many purposes.
Old Jan 2, 2018 | 04:02 PM
StarFox's Avatar
StarFox
I can't complain Tedster9, although it is colder than normal here. From Boston originally I know the cold very well. But Iowa? Yeah, colder than Boston...best have a garage to work in.
That wire is good and stiff Ted928. I too keep that kinda stuff around the house as it comes in handy. I do have a long piece of similar wire, but I think if I get me a 90 degree pick with a handle on it I could likely get more leverage with it. I seem to recall that Harbor Freight has those in a pack, I'll be stopping by there after work today to look.
Thought about crushing it, but with an aluminum head.....
I'm going to get a larger hose that fits into the spark plug cavity, the smaller hose I'm using doesn't have enough pull for a stone.
Thanks for the replies!
Old Jan 2, 2018 | 04:59 PM
Ted928's Avatar
Ted928
You have a Harbor Freight within "stopping by" distance - you sir are a lucky man.
Old Jan 3, 2018 | 12:40 PM
StarFox's Avatar
StarFox
Two Actually!! One near work and one halfway home....The advantage I guess of traveling 100 mi a day for a commute.
Success last night with Cylinder #3 :-)
I was able to move the obstruction with the probe I picked up from HF, but not out. I then upgraded my vacuum hose to one with twice the inside diameter and that did the trick. The plug resisted at first but came out easily.
So, 4 for 4 on plug removal on the passenger side....now I can tackle the others.
