Anyone got a part number for this pump and pulley? Mine is dead and I’m tired of listening to it. Not sure which truck it actually came from, but it’s on my 460 now.
Welp there are lots of aftermarket choices for your pump, if you want to keep the fluid reservoir (i would cuz they serve a purpose and look old school) than try
A-1 CARDONE 206240F
ATSCO 7056
ACDELCO 36P1193
Your going to want to remove your old pulley and press on your new pump...Pulley pullers are cheap and you can rent of from your local parts store...
I'm my experiences if you put a rebuilt C2 pump back on your likely to have the same issues. Lots of brackets available for big blocks no custom brackets needed for a Saginaw
1978 and later F100/350 & Bronco use the Ford C-II P/S pump that has a plasticreservoir. The P/S pressure hose attaches to the pump w/a qwik connect fitting.
1975/97 Econolines use the Saginaw P/S pump. You'll want one from a 460.
