94 Explorer check engine light
Old Sep 13, 2003 | 02:41 PM
dan1958's Avatar
dan1958
I have a 94 Explorer with a 4.0... The check engine light started to intermittently come on earlier this week and now it stays on all the time. The idle is rough and there is black smoke coming from the exhaust. Does anyone have any idea on what might be going on before I take it in to see what codes I'm getting out of it.
Thanks,
Danny
Old Sep 13, 2003 | 04:58 PM
Opera House Works's Avatar
Opera House Works
I'd check the vacuum line fron the fuel pressure regulator for the presence of gas first. If the regulator leaks, it will dump gas right into the intake manifold causing a rich condition. The only other thing would be a leaking injector.
Old Sep 13, 2003 | 09:40 PM
dan1958's Avatar
dan1958
Thank You for the info... I'll check that out!
Old Sep 14, 2003 | 11:28 AM
mrshorty's Avatar
mrshorty
If you feel like it, pull the codes yourself before you take it in to someone. On a '94, all you need is a short piece of wire (paper clip?). The codes come up as flashes of the CEL. Detailed instructions for pulling codes can be found at www.dalidesign.com/hbook/eectest.html or in any good repair manual.
Old Sep 14, 2003 | 03:24 PM
dan1958's Avatar
dan1958
I did and I got a code 157...... MAF sensor I think!!!
Old Sep 14, 2003 | 08:59 PM
thelonerangerxlt's Avatar
thelonerangerxlt
Yes, MAF signal voltage too low; classic sign of dirty MAF wires. You might try cleaning it before replacement. If you do a search, there's plenty of descriptions on cleaning procedures.
You can also unplug the MAF connector, spray it with WD-40, and re-plug. Ford had a lot of trouble with those connector plugs.
customfoam
Dec 20, 2008 04:36 PM
j94tbird
Apr 7, 2005 01:37 AM
jddaero
May 21, 2004 01:41 PM
brt
Jul 24, 2002 02:39 PM
chemist30
May 9, 2002 08:59 PM
